The info is on the ToyMods forum, I can't be arsed searching for it so I'll leave that up to you. Shifter bushes for the W58, that should be enough to get you started. There's a white bush and a green bush, and the part numbers for both are listed.
Jason T wrote:The info is on the ToyMods forum, I can't be arsed searching for it so I'll leave that up to you. Shifter bushes for the W58, that should be enough to get you started. There's a white bush and a green bush, and the part numbers for both are listed.
First replace the gear stick green seat cup and the gear stick white nylon bush
