Toyota soarer v8 auto, what can i use for replactment?
Postby headshotnz » Thu Feb 24, 2011 5:44 pm
Hey guys my auto box is slipping. time for a new one.
Question, will autos from a jzz30 jza80 or the celsior box work? i have mine to swap over things that are necessary, (yoke, driveshaft, bellhousing etc) can it be done or is it a no go cheers guys!
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby headshotnz » Thu Feb 24, 2011 5:54 pm
Well i just brought a celsior box for $1 please some one give me some good news :) google doesnt have the answers i need.. picture if required!
headshotnz
Postby holden_fan2005 » Thu Feb 24, 2011 6:31 pm
Got any more for $1? :)
What are the numbers? From what I gather ya need 30-41le. My 93 uzz31 had the rubber output shaft like that one.
From what I have researched the bellhousing/torque converters are smaller/thinner in the jzz30s, maybe someone could confirm this?
http://www.toymods.org.au/forums/showthread.php?t=4446
Also, a good read.
Edit: Also, another easy what I can think to tell is pull the pan off. If the valve body is the size of the pan, it's the more complex box (what we need for the soarers). If it's a small valve body (half of the pan size) it's the more simple box, used in the supras/jzz30s I think??
holden_fan2005
Postby headshotnz » Thu Feb 24, 2011 6:43 pm
haha i wish, just slapped celsior into trade me toyota/gearboxes and there was one closing in 4 minutes with a no reserve! done deal ;)
Ill post up more info when i get it as the auction has no information..
Cheers for ya help mate and ill have a read now
Edit: my soarer has a a341e box, and with a bit of reading thats the only box that comes in the ls400.. hmmm
headshotnz
Postby headshotnz » Thu Feb 24, 2011 7:41 pm
Model No: 30-41LE, serial no. 93K E 03970, also has Aisin 8930-32 up higher on the box.
What do we reckon team??
headshotnz
Postby spencer » Thu Feb 24, 2011 9:43 pm
Theres plenty of slight variance with a340's, some with cable kick downs, or PWM pressure control, or an extra solenoid
In your case if the plugs on the loom look like they will fit this box theres a 99% chance its sweet to bang it in. Double check the bellhousing is identical
Also cant hurt to chuck a filter at it while its out and clean the pan. Then flush the $&#$% out of it when its in and running. i would recommended Toyota fluid and lots of it like 12L
ms63 crown
spencer
