christchurch is out of premium gas...
Postby Tagged » Fri Feb 25, 2011 10:35 pm
just a quick question, is it alright for me to fill up 91 gas for my 4A-GE engine?
I know its probably not very good to use 91 on high compression engines....but I don't really have much choice atm....
Tagged
Postby d1 mule » Fri Feb 25, 2011 10:38 pm
it will be fine if you dont cain it. i had to fill up with 95 in my work van (5k) cuz they had no 91
d1 mule
Postby h8wrxs » Sat Feb 26, 2011 12:08 am
itll run fine, just wont run as well as premium
throw in an octane booster if your worried
h8wrxs
Postby gleem » Sat Feb 26, 2011 7:46 am
i used to run my blacktop all the time on 91. Crashed after 2 years and sripped it and at 198xxxkms the head, ports and pistons were mint as.
No issues at all on mine
gleem
Postby Tagged » Sat Feb 26, 2011 5:23 pm
cool~ thanks guys
Tagged
Postby andrewgreen1000 » Sun Feb 27, 2011 6:04 pm
for what its worth, BP in fendalton has 98 still, if you go at about 10pm, there are no lines etc.
Current: '99 Ae111 Sprinter GT, '12 Aqua
Gone, but not forgotten: '81 KP Starlet, '92 Ae101 Truneo, '97 BZ-Touring Carib, '96 LWB Bighorn, '96 Bogan mobile Levin.
andrewgreen1000
Postby Tagged » Sun Feb 27, 2011 6:23 pm
andrewgreen1000 wrote:for what its worth, BP in fendalton has 98 still, if you go at about 10pm, there are no lines etc.
real? I actually went there twice, 1st time there aint any 98 left, and 2nd time which is 2day they told me there isn't any left either...when did you go?
Tagged
Postby Bling » Sun Feb 27, 2011 7:03 pm
It's no wonder there is no gas when people are driving around ALL DAY looking for gas.
Probably the only reason we ran out too, too many people rushing out to fill up as the world is going to end. No matter how many times they say on the news not to stockpile, you still see queues :roll:
Postby andrewgreen1000 » Sun Feb 27, 2011 7:14 pm
I was there last night (sat) at 10pm, was fill up day day for me anyway, was way below E! Must have run out this morning?
andrewgreen1000
Postby molex » Sun Feb 27, 2011 7:57 pm
You should run a modern high compression knock controlled engine on the highest octane fuel you can economically buy. With higher octane rating comes increased knock resistance, ECU will compensate over time by advancing timing, increasing power/reducing fuel usage. Plenty of tests have been done, running 95 will actually result in cheaper $/km in most cases.
Wouldn't bother in a 5k powered van but better fuel certainly isn't going to hurt it!
Went through a station the other day, only gas station for 90km and they had run out of 91. People would see the sign and rather just putting in some 95 they stormed off in a huff. All in modern (e.g '04+) cars which should have never been run on 91 in the first place :roll:
Lots of ignorance around fuel types
molex
Postby h8wrxs » Sun Feb 27, 2011 10:01 pm
there obviously are reasons for higher octane fuel being better but a car will still run on 91
im assuming the car in question is pretty standard so its not going to make any difference to run cheap fuel for a few hundred kms
h8wrxs
Postby allencr » Mon Feb 28, 2011 1:45 pm
You should run with the LOWEST octane that's compatible with your engine & driving, as anything higher is just wasted & does nothing for performance or engine life/longevity.
Yes, knock sensor be good, really good with an open exhaust when you can't hear the detonation.
If you wanna have the most performance you can get from octane & advanced ignition timing, or you're someone who likes to accelerate from 2000-2500rpm in 3-4-5 gear, then the engine will need the higher octane.
allencr
Postby Mr Revhead » Mon Feb 28, 2011 2:36 pm
Will pink like a bitch on 91 and you will notice the rougher running.
They need the timing knocked back to run ok on 95
Users browsing this forum: Google [Bot] and 21 guests
