the fallen303 wrote:probably just spend the money from the conversion on single/ecu/fuel, and would end up with similar low end torque you were after, with not more up top *shrugs*
Rookie wrote:Yes Sergei you are wrong, flow bench testing is very representitve of what goes on in real life, if you do it correctly. And Yes I would say that TK can make a head flow miles better than stock, the results are there in the link I posted. You would be deluded if you think that you couldn't do a better job on one head than yamaha/toyota do in a production line of a million. Read the link and then decide.
