Seat belt mounting
Seat belt mounting
Postby Kiwi6539 » Fri Mar 11, 2011 3:20 pm
Hello Just want to see if anyone has has mounted a 3 point seat belt into ae82, And doubled up the the bottom retactor and belt on same bolt hole?
Ive just noticed my roll cage covers one of the orignal mounting holes. the one for retactor, so would like to know if anyone has mounted them on the one hole. To avoid having to get full lvvta cert for it?
Hope this makes some sense?
NZ New AE82 Gt race car
Kiwi6539
Postby Distrb » Fri Mar 11, 2011 3:40 pm
do you have a full rollcage?
If you do and you want to have it road legal, you cannot run a 3 point lap belt, and you MUST run a minimum 4point harness with an authority card.
Distrb
Regular Poster
Postby Kiwi6539 » Fri Mar 11, 2011 5:59 pm
Hey
Yes it has full roll cage. I understood you had to have lap belt for warrant?. I was planning on having both as the car wil be road legal.
Ive spoken to a A grade scrutiner who i will see for authority card, and told him i was planning on getting it with just lap belt until i can afford harness. Which he said was fine.
Will speak to motorsport nz to find out what the rules are.
Still want to know if anyone has doubled up seat belt fittings on one mount.
Kiwi6539
Postby Distrb » Fri Mar 11, 2011 6:06 pm
It is not fine. Schedule a is pretty clear in this area:
http://motorsport.org.nz/assets/MotorSp ... A-2010.pdf
Sch A - Appendix 8, Section 2 wrote:
Safety Cage (Rollcage) – Where a rollcage is fitted to a motor sport vehicle used on public roads an Authority Card is required. The following requirements shall be met:
(i) The rollcage shall comply with the requirements of this Schedule, and
(ii) The structure should not intrude into the occupant’s headspace as defined in drawing 8.2.3, and
(iii) Have protective padding fitted that complies with the requirements of this Schedule and shall additionally be fitted to any side intrusion bars where they are not shielded by the seat structure, and
(iv) Have safety harnesses (minimum 4 strap) fitted to the front seating positions in compliance with this Schedule, and
(v) Any rear seating positions shall be removed or not used to carry passengers, and
(vi) Any 3 strap lap and diagonal safety belts (originally fitted by the manufacturer) shall be completely removed.
Distrb
Regular Poster
Postby Leon » Fri Mar 11, 2011 6:34 pm
He is very wrong, as per Andrew's quoting. I too am "A" scrutineer
Postby Kiwi6539 » Fri Mar 11, 2011 7:12 pm
Hey guys
Thank you for the information. This clears it up for me.
Maybe I didn't explain what I was doing enough.
So now I need to get a harness. Any advice on what 5 point harness I should go for?
Kiwi6539
Postby Leon » Fri Mar 11, 2011 8:09 pm
FIA standard
Not SFI spec.
Not Silvester brand (have seen two pairs of them crap out very very very quickly, plus the adjustors are a stone cold bitch)
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
