AE101 FXGT - Tacho problem
Postby Santa'sBoostinSleigh » Sat Mar 12, 2011 10:33 am
CarpetBurns AE101 FXGT factory tacho has decided to stop working...
when driving along at 100kph it sits at about 500rpm, even when you give it death, it kinda just bounces around and might read 1000-1200rpm
easy fix?
i think ive got another dash etc in the parts car, so could fit that, but then will end up with a random odo reading
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby solitaire » Sat Mar 12, 2011 11:18 am
Any error codes? Tick in the box stuff but it will tell you if the ecu is unhappy about the rpm signal, you would think if the ecu was getting a dodgey signal the car would run a bit weird?
The might help, ae101 ecu pinouts, you could trace the cable from the ecu?
http://opc.mr2oc.com/online_parts_catalog/20valveTO16valve/20%20Valve%20Pins%201999.doc
Hopefully some continuity testing should give you an idea of the issue
AE92, KZJ120, KDJ120
solitaire
Re: AE101 FXGT - Tacho problem
Postby matt dunn » Sat Mar 12, 2011 5:59 pm
Santa'sBoostinSleigh wrote:i think ive got another dash etc in the parts car, so could fit that, but then will end up with a random odo reading
you can swap the tacho without swapping the speedo, they are separate.
Postby Santa'sBoostinSleigh » Sun Mar 13, 2011 9:01 am
mint, that will be option #1
off to the NP Rodders Street drags today doing fire cover (im going to cook wearing level 2 structure fire fighting gear all day)
but tomorrow is Taranaki Anniversary Day, so its fix cars day
Santa's Mega Sale
