i haven't paid much attention to the spark plugs i'm running up till now and i think it may be an area where i should be refining it a bit.
these are the two sets of plugs i have run in my car since i got the engine in, the original denso's (PK20R11) and then some NGK BKR6E-11's
so from what i've read the NGK suffix '11' means they are gapped to 1.1mm. is this about right for a NA 20V? how would changing compression affect the gap i would want to run? i know smaller gaps are better for turbo applications due to the lower compression.
now i know there are ways to tell how healthy your engine is running by looking at the tips of the plugs. to me it looks like there has been detonation going on with my NGK plugs as the end is quite white and looks burnt. as you can see above.
so what are the advantages of different tip designs and what is the best for each scenario?i notice the denso plugs have a pointed tip and the NGK plug has the valley down the middle of the flat tip.
i talked to a real interesting salesman once who explained everything but i have since forgot so thought i would ask for a bit of info.
