oil return fabricator reqd please. CHCH.
Postby BlakeNZ » Wed Mar 23, 2011 9:21 pm
Hi, i have an associate in Christchurch who needs a custom oil return fabricated to complete his single turbo conversion on his Soarer. Can anyone suggest a name/ contact/ friend please?thank you.
BlakeNZ
Postby d1 mule » Wed Mar 23, 2011 11:18 pm
iv not sceen a soarer return before but based of all the other returns iv seen, there will be the factory return pipe that goes back into the block. Go to cylinder head specialists/japrace and they will have a fitting you can bolt onto your turbo that had the same size fitting as the factory drain pipe. connect with oil hi temp hose and your done. like this ish, might not be perfect but has worked mint so far
d1 mule
Postby YeMs » Thu Mar 24, 2011 6:44 am
thats pretty much what iv always done. you can go as far as getting a dash weld-on and making up a fancy-ass braided return, but at the end of the day its a low pressure return.
with a soare, you will just have to either modify the flange on the block for the return or block one of the inlets off (as the factory has 2 returns)
Your local Hybrid Elite tech
YeMs
Re: oil return fabricator reqd please. CHCH.
Postby MrOizo » Thu Mar 24, 2011 2:06 pm
So its a 1JZ or a V8?
But yeah like has been said, if a 1JZ i have seen people weld up one of the 2 returns.
I was looking up this last week and found these - a -10 fitting for a JZ:
from http://www.arizonaperformance.com/
MrOizo
Toyspeed Legend
Postby BlakeNZ » Sun Mar 27, 2011 7:05 pm
thanks for your input, guys.
On this particular 1jz, the oil return pipe runs very close to one of the runners into the manifold, so the first 100-150mm of oil return line ideally needs to be steel.
BlakeNZ
Users browsing this forum: Bing [Bot] and 11 guests
