how do i turn idle down in ae101
Postby vr4boy » Mon Mar 28, 2011 8:54 pm
cant work out how to turn the idle down as it ildes at 1100rpm when warm, its a silvertop if that helps.
1995 ae101 levin st 20v
vr4boy
Postby Mr Revhead » Wed Mar 30, 2011 1:38 pm
Is this anything to do with your conversion questions?
Postby vr4boy » Wed Mar 30, 2011 4:43 pm
no, havnt got that far yet, still got silvertop in, just the high idle is annoying me.
vr4boy
Postby ATAl » Wed Mar 30, 2011 6:28 pm
First is the iscv valve working properly - it's the one with an air hose running into the top of the intake manifold right near the head. This controls the idle speed normally.
It's possible the throttle bodies are adjusted incorrectly and are letting through more air than the iscv valve can compensate for. To adjust the throttle bodies remove the plenum, then there are small screws on the end face of each throttle body, screw these in to decrease idle. It's probably a good idea to screw them in the same amount each as otherwise you'll get the throttle bodies out of balance.
ATAl
Postby fevil » Thu Mar 31, 2011 10:36 am
Had same problem (bt 20v). Cleaned iscv and that brought idle down to about 1000rpm ish. Replaced the thermostat and now idles at 900rpm hot.
fevil
Postby Flannelman » Fri Apr 01, 2011 10:00 pm
Also found there is an adjustment screw on the Vane airflow senser. Clockwise is to lower RPM, Anti-clockwise is to raise RPM.
Flannelman
formerly known as Affroman
Postby Mr Revhead » Fri Apr 01, 2011 10:32 pm
NO! That's to adjust the Afm. Don't $&#$% with it
Postby Flannelman » Mon Apr 04, 2011 8:57 pm
OOPS! :oops:
Flannelman
Postby Bazda » Tue Apr 05, 2011 12:06 pm
Yea I would not touch that, it changes the mixtures.
If you take the plenum off, there are 4 individual screws for each throttle body. Those adjust the idle.
yes you have to remove the plenum to do this!
