Catch can design
Catch can design
Postby pureadrenalin » Wed Mar 30, 2011 12:28 pm
While doing a re-build on my race car, I'm looking for a new catch can.
I can't find one I like.
Are the things I'm looking for necessary?
1. to be able to open it up (not fully welded)
2. two 1/2" NPT inlet ports
3. vent filter
4. drian fitting.
I don't care if it has a clear pipe for a level gauge.
I did a quick model of one with stainless steel fittings I can purchase.
Simple clamp, with a flange that looks like an exhaust v-clamp with a blank for a lid.
I intend on filling it with stainless steel wool.
What do you think?
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby iOnic » Wed Mar 30, 2011 6:07 pm
Why do you want to open it?
Postby pureadrenalin » Wed Mar 30, 2011 8:19 pm
Not sure exactly. Just a normal want to be able to inspect everything on the race car. If something is sealed, I can't check, inspect, replace, upgrade, easily.
pureadrenalin
Re: Catch can design
Postby allencr » Wed Mar 30, 2011 10:19 pm
pureadrenalin wrote:3. vent filter
Filter what & for what reason?
Blowby exiting the engine isn't going to harm the Earth any less from being filtered.
Air entering won't happen when running, won't matter when stopped. It will protect curious insects.
allencr
Postby pureadrenalin » Thu Mar 31, 2011 12:31 pm
Vent filter just to hopefully catch the last of the oil vapor before it decides to deposit itself all over my engine bay.
pureadrenalin
Postby iOnic » Thu Mar 31, 2011 5:21 pm
Filter keeps things nice and clean. If you're going to have it so you can open it and inspect it could you just do away with the drain altogether and use the inspection time as an opportunity to drain it too? Or are you plumbing the drain back into the block/sump?
Can't see anything wrong with your design. Looks good and should do the job well.
Postby Mr Ree » Thu Mar 31, 2011 6:52 pm
I would recommend filling it with "steelo's" to act as a baffle for the oil/condensation to cling to.
Mr Ree
Postby Lurkin » Thu Mar 31, 2011 7:01 pm
nice - exactly what I have been looking for as well. not written on your post - but considered size? pretty sure I've read on here there are requirements regarding size for motor sport? no pretending to know the ins and outs - but something to think about.
Have been thinking of a larger diameter fitting where the filter would go - to put a larger diameter pipe down behind the guard? wasn't sure how much mess they make with a filter on...
can you PM me when you find one/ someone to make it? could be interested as well.. cheers!
Past casualties
1986 4age liftback (sold)
Lurkin
Postby QikStarlie » Thu Mar 31, 2011 7:26 pm
run the biggest breather pipe /pipes from the cam cover you can. less velocity will mean less oil is throwen out to start with.
QikStarlie
Postby Stott69 » Thu Mar 31, 2011 8:33 pm
Theres a couple of guys that have designed these on here, both in palmy too. the steel wool idea is a goer tho I think
Image jzs147 Aristo money pit
Stott69
Postby sergei » Thu Mar 31, 2011 9:23 pm
I was thinking of making a funnel like in dyson vacuum cleaner so the oil centrifugally would be deposited on the walls.
Postby Bling » Thu Mar 31, 2011 10:03 pm
I think you should think more about SC'ing that Ist :lol: :wink:
What about a wingnut or similar to hold the lid on?
Postby sergei » Fri Apr 01, 2011 8:21 am
BZG|Bling wrote:I think you should think more about SC'ing that Ist :lol: :wink:
Or getting my ST165 going...
:lol:
Postby pureadrenalin » Fri Apr 01, 2011 10:27 am
Size wise to meet motor sport regulations at 4" diameter I'm using, it only needs to be 100mm long. I'm making it around 180-200mm.
I'm intending on running two AN10 lines from my cam cover.
pureadrenalin
Postby pureadrenalin » Fri Apr 01, 2011 10:29 am
Stott69 wrote:Theres a couple of guys that have designed these on here, both in palmy too. the steel wool idea is a goer tho I think
I'm happy to gather up all the bits if someone can weld it up for me, otherwise I'll have a go with a mates tig.
sergei wrote:I was thinking of making a funnel like in dyson vacuum cleaner so the oil centrifugally would be deposited on the walls.
I was thinking of the same thing, and where I work, we design these kind of systems for the oil and gas industry, but it all just got too hard :lol:
pureadrenalin
Postby Santa'sBoostinSleigh » Fri Apr 01, 2011 11:37 am
Garniee, either me or a guy I know would be able to TIG it up for ya
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby gt4dude » Thu Apr 14, 2011 2:51 am
Are there regulations for motorsport use?
I heard it has to be 2L and filtered if not running sealed system?
Also, do you run separate tanks for PCV and breather ports? Or run them both into the same can?
Do you swap the PCV valve for a large metal nipple that fits the hole?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby matt dunn » Fri Apr 15, 2011 12:10 am
gt4dude wrote:Are there regulations for motorsport use?
Motorsport rules are,
up to 2000cc needs a 1L catch
and 2000cc one over needs needs a 2L catch,
unless it is a sealed system i.e. the PCV valve is still there and feeds back into the intake in which case there is no catch can at all.
Postby RomanV » Sun Apr 17, 2011 10:16 am
gt4dude wrote:Also, do you run separate tanks for PCV and breather ports? Or run them both into the same can?
They both get air/fumes from the same place, so no need to seperate them. Could probably just have one blocked off, but probably better to have both feeding the tank I guess.
