Using a petrol tacho on a deisel?
Postby cat007 » Fri Apr 01, 2011 12:00 pm
I'm told that you can pretty much use any tacho on anything as they just run off the alternator?
I'm wanting to put this on my boat which has a 2 cylinder diesel - the alternator has a tacho output....
Wanting to use something like this as it has volts as well...
http://www.trademe.co.nz/Trade-Me-Motor ... 600022.htm
Hunt
Postby Burning Angel » Fri Apr 01, 2011 4:46 pm
no petrol tachos are triggered off the coil negative on aftermarket ones and sometimes the ecu on factory ones
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby cat007 » Fri Apr 01, 2011 4:53 pm
Burning Angel wrote:no petrol tachos are triggered off the coil negative on aftermarket ones and sometimes the ecu on factory ones
Apparently this tacho can be triggered off the alternator
Postby matt dunn » Fri Apr 01, 2011 7:50 pm
There is a tacho adapter available to make petrol type tacho's run off an alternator signal.
Postby cat007 » Wed Apr 06, 2011 12:19 pm
matt dunn wrote:There is a tacho adapter available to make petrol type tacho's run off an alternator signal.
Yeah? I can't seem to find anything - apparently I'm doing a man-look lol
Postby matt dunn » Wed Apr 06, 2011 9:06 pm
We have them in stock at work, not sure where they come from or what they are worth? have not fitted one in years.
Postby cat007 » Wed Apr 06, 2011 11:42 pm
matt dunn wrote:We have them in stock at work, not sure where they come from or what they are worth? have not fitted one in years.
Probably only worth a box a beers I'd say ;)
Postby cat007 » Mon Apr 11, 2011 12:34 pm
Ok so the tacho I have has a switch for 3, 4, 6, or 8 cylinder operation
Running it off the alternator the lowest I could with the dip switches on the rear of it was reading about 4,500rpm when the engine was idling at about 600rpm....
Bugger - was really hoping to use this tacho as it has a volt meter on it which is quite crucial to know what the batteries are doing....
Postby Bling » Mon Apr 11, 2011 3:52 pm
Postby cat007 » Mon Apr 11, 2011 4:09 pm
BZG|Bling wrote:http://www.dealextreme.com/p/2-2-lcd-digital-panel-voltmeter-with-blue-backlight-7-2-20v-36147
For voltmeter.
Yeah thought about something like that - but just not so keen on cutting odd sized holes lol
Users browsing this forum: Bing [Bot] and 14 guests
