4age oversized pistons
Postby tim_blair » Mon Apr 11, 2011 6:27 pm
im thinking about buying over sized pistons from toda for my black top
they sell 82mm (1mm over size) high comp pistons
for $1500nz
is it worth getting these or can i get something simalar for cheaper elsewhere?
also what is the maximum safe oversize limit?
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby rx7guy » Mon Apr 11, 2011 7:25 pm
No. Get something else cheaper.
The torque band is wide and the road is narrow
rx7guy
Postby tim_blair » Mon Apr 11, 2011 7:49 pm
ok but where from?
tim_blair
Postby Dell'Orto » Mon Apr 11, 2011 7:55 pm
Probably not many options for forged high comp pistons. Denco could make some, or Wiseco/JE might do something off the shelf, likely to be similar money though.
Max oversize depends on how thick your block is.
Postby XSVWGN » Mon Apr 11, 2011 9:35 pm
whats the plan for the engine? you wanting to stay NA? Just save yourself the cash and buy daniels BZR. :wink:
Matt
2008 Kia rio - work car
XSVWGN
Postby tim_blair » Tue Apr 12, 2011 8:21 pm
yea im gona go na
what makes daniels bzr so special?
tim_blair
Postby QikStarlie » Tue Apr 12, 2011 8:28 pm
run 82mm toda's in my 16v. nicely finished pistons. they dont run wide clearances so no piston slap when cold. would be nice if they offered higher compression version like 12.5:1
QikStarlie
Postby 1I1 » Tue Apr 12, 2011 8:34 pm
tim_blair wrote:yea im gona go na
Everything is there done for you
viewtopic.php?t=81598
10k is pretty cheap compared to what it would cost to build with all the good gear
TRD Clicky >>Here
1I1
Postby XSVWGN » Wed Apr 13, 2011 1:18 am
yea doooo it! Daniel has spent shitloads on his car. I know that buying his one you loose the thrill of building something yourself but man it saves some serious cash and alot of hassle!
Matt
XSVWGN
Re: 4age oversized pistons
Postby allencr » Wed Apr 13, 2011 8:46 am
tim_blair wrote: is it worth getting these...
Is it a racing engine or turbo/super charged? Racing engines are never driven on the street, it's just a high performance street engine.
If the intake & ECU & cams & exhaust aren't being changed/modified, then no, it's not worth getting them.
allencr
Postby tim_blair » Thu Apr 14, 2011 8:37 pm
wow that is a monster of an awesome car!!
but sadly i get way to much pleasure out of building it myself
and i dont have a spare 10k atm
its gona be a street car im getting the engine rebuilt with machining and figured i may as well get some hot pistons while its apart
i was going turbo but i weighted up the costs and its just to much
im doin the exhaust and intake and ecu, and will eventually do the cams futher down the road
not really after alot but more after a fresh engine thats beter than it was
plus i want that itb roar back 8)
tim_blair
Postby tim_blair » Thu Apr 14, 2011 8:51 pm
oh by the way i have a shit load of 4age turbo parts that im selling
plenum 3inch inlet/pipe all the way with trumpts bout 60mm long
stainless extractors t25 flange (moded so they actually fit...) with 38mm adjustable waste gate
fabed 2.5 inch 316 stainless turbo exhaust outlet with v-band clamp and wastegate plumb in
4agze rod and pistons some other parts
intercooler piping
bov
tim_blair
Postby QikStarlie » Thu Apr 14, 2011 9:59 pm
sounds like you'd be better off with standard pistons, head skim and trd gasket.
QikStarlie
Postby Lurkin » Thu Apr 14, 2011 10:42 pm
are the 4agze pistons new? or used? how much do you want for them? pm me. could be interested in other turbo bits...
Past casualties
1986 4age liftback (sold)
Lurkin
Postby d1 mule » Thu Apr 14, 2011 11:10 pm
dude are you $&#$% serious??
you are building an engine, you already have most of the gear to turbo it, and say you are getting a ECU to run it all but say its going to cost you too much to turbo it.
you will spend a quarter as much turboing it as you will making it a descent N/A engine and will have twice the power with turbo.
what you said is bordering on ridiculous.
d1 mule
Postby Bazda » Fri Apr 15, 2011 9:43 am
You can get 81.5mm standard OS pistons from Toyota.
Postby DFECTED » Mon Apr 18, 2011 9:26 pm
hey man you came into my work, custom works. You should keep it turbo and get some .5mm oversize forgies and another turbo, probably both for $1500
DFECTED
Postby tim_blair » Tue Apr 19, 2011 11:15 pm
i am wanting to buy daniels bzr
but i cant get hold of him
does anyone know how i can?
i haved called him,txt him, emailed and PMed him.... but no reply
tim_blair
Postby tim_blair » Tue Apr 19, 2011 11:24 pm
hey dfected if i cant get this other guys car ill defo come to you to get my engine work done
im having way more fun driving it NA so im defo gona keep it NA but ill have to wait and see if i get this other car or not as to what i do
tim_blair
Postby Bling » Wed Apr 20, 2011 12:44 am
He must just be busy mate, give him a couple days to get back to you. He won't be ignoring you :)
