Extremely stiff clutch pedal
Postby -Justin- » Thu Apr 21, 2011 3:49 pm
Not a Toyota related question but the guys on here know their stuff. Anyway about a year ago i converted my r32 from auto to manual at the time a heavy duty rb25det clutch was available so i put that in. I am pretty dam certain i greased everything and installed everything properly(did a few manual conversions previously). After bleeding the clutch i found that it was very very hard to push in i mean the fly wall flexes a little bit, i used all genuine r32 20det parts. I have asked around and even a mate said that even a 25det clutch should not be that heavy. Anyway long story short i really don't want to have to pull my gearbox out just to change a clutch that isnt slipping with a standard 20det one. i have had a look on the net and their are such things as "clutch boosters" stageas run them factory. Had a look on trademe could not find anything, so my question is does anyone have any suggestions on how i could go about solving my problem without having to pull the whole gearbox out again?
-Justin-
Postby DRFTIN » Thu Apr 21, 2011 5:38 pm
change the size of the slave cylinder
DRFTIN
Postby ch4ng » Thu Apr 21, 2011 7:03 pm
If everything is lubricated properly in the gearbox, check to make sure your clutch pedal joints and master/slave cylinders aren't seized.
If not then go for a bigger master cylinder
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby rollaholic » Thu Apr 21, 2011 10:14 pm
being more specific about the nature of the new clutch might help people tell you what the pedal might feel like from their experiences etc.
Postby Rob » Thu Apr 21, 2011 10:14 pm
A mate of mine put R34 GTT motor and box in his R32 and nothing was changed after the heavy duty clutch was fitted, so I think it sounds like something inside the bell housing is wrong
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
