gleem wrote: My 20det cefiro keeps heating up to fast when doing burnouts.
iOnic wrote: do you still have the shroud around the fan?
strx7 wrote:put the viscous fan back on, they shift more air than electric ones ever will
gleem wrote:People ive seen use 1 or 2 fans and some alloy sheet metal as a shroud. But im not to keen to spend that much for it to bent around a lamp post.
d1 mule wrote:in my experience "big alloy" radiators cause more problems than they are worth.
couple years ago there were a bunch of guys in drift south that had huge issues with aloy rads, like $&#$% engines all over the place/constantly overheating.
waste of time imo
True-No-Turbo wrote:d1 mule wrote:in my experience "big alloy" radiators cause more problems than they are worth.
waste of time imo
Really?, I wonder why?
I would of thought extra flow would be an advantage alloy or not.
d1 mule wrote:True-No-Turbo wrote:d1 mule wrote:in my experience "big alloy" radiators cause more problems than they are worth.
waste of time imo
Im no hydraulic/thermal engineer but my best guess would be that due to the large increase in radiator capacity, the water flow in the radiator would slow down to a point where there wasnt enough water circulation to cool anything.
Couple that with the fact that once the alloy tanks etc get hot they will be acting like big heaters also hindering the cooling ability of the radiator.
might not be how it works but from what iv seen they cause more harm than good if oversized, specially in drift/skid cars
d1 mule wrote:Im no hydraulic/thermal engineer but my best guess would be that due to the large increase in radiator capacity, the water flow in the radiator would slow down to a point where there wasnt enough water circulation to cool anything.
Users browsing this forum: Google [Bot] and 20 guests
