I've got a NZ-new GX71 with the 1ge in it and want to swap in a 1gge. I've been lead to believe this swap is pretty straightforward. I know I'll need to use DOHC ECU, AFM and powersteering gear and change radiator hoses around.
Can I use the SOHC loom or will I need the gge one?
Will the DOHC exhaust manifold bolt up to my standard exhaust flange?
Are there any other tricks involved?
Cheers.
