5L diesel starter motor questions...
Postby AE85.6 » Wed May 04, 2011 8:37 pm
First of all the symptoms...
Possibly starter is on the way out, cranks fairly slow from time to time which I think the battery maybe be helping although not root cause.
Now a couple times when starting I had no crank and just heard I think the solenoid click, if I tap the starter it will crank the next time.
If replacement is the way to go then fine but just want to know how interchangeable the "L" series starters ? i.e 2/2Lt/3/5L engines ?
I know there is a few different ones which are mainly due to 4x4 ones having battery lead on the other side ? but I have also heard there is a reduction type one which could be good for easier cranking although I do not know what car to check for these from ???
This would be to suit a 2wd ln85 hilux fitted with a 5L and only 1x battery on the drivers side.
Cheers all,
Mike.
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby gepsk8 » Fri May 06, 2011 12:43 pm
say both starter & Battery
O272754663
gepsk8
Postby mikeBrotherd » Fri May 06, 2011 2:39 pm
Im 99% sure that your starter will already be a reduction type. As for your symptoms, very common on toyota diesel starters for the solenoid contacts and brushes to get worn (they wear down with normal use)
They are quite easy to remove from the vehicle and even easier to repair. Almost all sparky shops will hold the parts needed to repair on stock and also If you take the starter into a shop i wouldn't expect to pay more then $150 all up.
Dont bother trying to find a S/H unit as it'll cost more then repairing yours :?
EDIT: ohh and it always helps to just replace your batt if its over 5years old (about the best service life on a diesel vehicle). Try to replace it with the same size, should be something like an NS70 or at least a 13plate type with 500CCA or bigger
    JZS147 Aristo, 2JZ-GE
    KE70 Corolla Wagon, 4K, 5spd Man
    JZA70 Supra, 2JZ-GTE, Man, TurboR
    GA60 Supra, 1G-E
mikeBrotherd
Postby AE85.6 » Fri May 06, 2011 3:32 pm
Cheers guys.
Ye I think at this stage it is a bit of both starter and battery and yes it has a ns70 in it at the mo so don't wanna go any smaller that that anyway.
Will still try to pinch the old mans meter on the weekend and see if it drops badly at crank as I think it is getting a bit tired, if it is ill start with swapping the battery then look at getting the starter reco'd maybe, I thought diesel ones were a bit different to petrol ones like had a different gearbox type centre or something ? Also I saw some on trade me saying 10 tooth and some 11 tooth so thought more teeth, more reduction and easier crank ?
AE85.6
Postby ee904age » Fri May 06, 2011 6:45 pm
AE85.6 wrote: Also I saw some on trade me saying 10 tooth and some 11 tooth so thought more teeth, more reduction and easier crank ?
No doubt someone will correct me if Im wrong, but you would only be able to replace a 10T with a 10T, and a 11T with a 11T, as changing it would make it not mate up with your ring gear. (Oh, and more teeth would effectively be higher gearing, therefore working the starter harder)
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby AE85.6 » Fri May 06, 2011 8:05 pm
Well yes that's what I thought but from memory it was advertised as a 11 tooth reduction type starter motor and an upgrade over 10 tooth ones ?
Might try and find the add again to re-read,
But I thought if the starter gear was 11 tooth and a bigger size it could still mesh into flywheel as normal but as I said I may just have read the add wrong.
AE85.6
Postby mikeBrotherd » Fri May 06, 2011 8:16 pm
Petrol and diesel definitely have a different ratio reduction, but the biggest difference is in the Kw rating of the starter. Seeing as you have a 5L engine i would say if its a genuine starter, it'll already be a pretty good rating, hence rebuild your one if you have to.
Yes if you remove a 10T, you replace it with a 10T.....generally... there is the exception on some bigger truck diesels and non-genuine starters. If you have a 10T and you get a 13T after-market unit, chances are it'll have an offset center to counter having more teeth. No real way of saying what will and won't fit though just off what engine they were removed from. Also on the same note, even if it does have more teeth, it wont necessarily work any harder as they accommodate the difference at the drive through the reduction gears 8)
    GA60 Supra, 1G-E
mikeBrotherd
Postby matt dunn » Fri May 06, 2011 11:16 pm
mikeBrotherd wrote:Yes if you remove a 10T, you replace it with a 10T.....generally...
It is quite common to replace starters with different number of teeth,
as the number of teeth is suited to the starter housing, ones with larger pinions are more off centered but still fit.
Mitsi's are quite common to interchange 9 to 13 tooth starters.
there are at least 5 different L series diesil starters.
they all interchange, but some have different connectors for the operating terminal, and there are large bodied ones and small bodied ones.
Postby allencr » Sat May 07, 2011 8:44 am
Lower ratio/higher number, less starter load, IS NOT getting a starter with more teeth!
allencr
Postby matt dunn » Sat May 07, 2011 3:33 pm
allencr wrote:Lower ratio/higher number, less starter load, IS NOT getting a starter with more teeth!
On paper you'd think it makes a difference,
in the real world it does not.
They are the most common starters we see.
We run 5 of them as exchange units at work,
and send them out and get them back without knowing what version you get back. Have never had a problem in 16 years and you cant tell hear or measure the difference between the starters.
The load on them usually makes no difference as the contact wear out 10x more than anything to do with the load on the motor.
Only thing that affects the life is normally the number of times you start it,
not the load on them.
Postby mikeBrotherd » Sat May 07, 2011 7:05 pm
Auto Sparky?
    GA60 Supra, 1G-E
mikeBrotherd
Postby matt dunn » Sat May 07, 2011 8:34 pm
mikeBrotherd wrote:Auto Sparky?
How'd you guess?
Postby mikeBrotherd » Sat May 07, 2011 10:37 pm
Mostly the familiar sounding workplace :wink:
    GA60 Supra, 1G-E
mikeBrotherd
Postby AE85.6 » Thu May 12, 2011 8:41 pm
Thanks for all the info guys,
Battery seemed to drop a bit low at crank so threw another in which was a bit of an improvement and I thought for a while even a solve, but sadly the starter is still sticking from time to time.
If all the starter options are fairly similar I think I might just take the starter off and drop to my auto sparky for the overhaul and go from there.
Hopefully that works for now but I also think the alternator could be a lil slow so that may be next on the watch...
AE85.6
Postby MAGN1T » Thu May 12, 2011 9:16 pm
Toyotas often have wiring faults that cause that. Is it manual or auto?
Best to test everything properly first / proper diagnosis.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby matt dunn » Thu May 12, 2011 10:03 pm
AE85.6 wrote:, but adly the starter is still sticking from time to time.
What do you mean by sticking.
Do you mean when you go to start it just goes click and nothing happens?
Matt
Postby AE85.6 » Sat May 14, 2011 11:04 pm
Matt,
ha ye sorry mean turn key and nothing happens or hear a click but no crank, prob more accurate than saying it sticks...
MAGN1T,
Ute is a manual,
When you say common wiring issues what should I be checking ?
I could not see anything obviously loose or anything, I was planning to clean all the earths and make sure any other connections are tight and not oily or corroded looking but have not as yet.
AE85.6
Postby MAGN1T » Sun May 15, 2011 8:30 pm
AE85.6 wrote:MAGN1T,
Ute is a manual,
I've never seen an point in swapping parts by guesswork without testing them first.
You need a voltmeter, hook it up to the solenoid connection and earth. Measure the voltage at the connection when you turn the key.
If it goes click but doesn't crank, you'll either have 12V, 0V or somewhere in between at the connection.
If there's 12V, the starter motor will be dud.
If there's not 12V then maybe the problem is elsewhere.
Often toyota inhibitor switches go high resistance but that only affects the autos. The manuals often have a relay in between the key switch and the starter solenoid.
Steve
MAGN1T
Postby AE85.6 » Wed May 18, 2011 9:59 pm
MAGN1T:
Cheers for that.
I have had someone go over it earlier on with a multimeter to test battery and whatever else that it could be at the time however couldn't get it to do the no crank while being tested, not sure if that could test same as what you have mentioned or not but it is probably more my lack of electrical knowledge to say what they tested and how as I don't really know how to drive a multimeter myself ???
I have since dropped the starter to my auto sparky for a reco and has been going sweet since.
Replaced worn contacts, plunger, refaced armature parts and clean and lube everything else. He said the contacts were worn but not rooted.
AE85.6
Users browsing this forum: No registered users and 30 guests
