Clutch Replacement for 2001 Fielder Z - Mechanic Suggestions
Postby FeetSteez » Wed May 11, 2011 1:20 pm
Hi All
As per my intro post, long time reader/rookie addition to the forums.
Had my car tested the other day and the only issue needing attention was a slipping clutch hence the need for replacement. It's not super-bad at this stage but will look into getting it replaced within the month hopefully.
I'm therefore looking for suggestions on reliable mechanics that can do the job for me/source the required parts. I have called a few places and had the following rough estimates:
- Toyota Albany: quoted $950 for an "upgraded" Exedy clutch kit, the flywheel machining, and labour;
- Quay St Autos: rough estimate of $600-700 including flywheel machining and labour;
- 2 other places gave estimates of $1000 and upwards.
With members' experiences:
(a) what should I expect to be paying for this kind of service?; and
(b) what are the best options? (including in-house suggestions).
I'm not after anything heavy duty, but would be interested in paying for an upgraded kit if the price was reasonable and worth it in terms of price/performance parity.
Many thanks in advance, I understand this is a fairly long-winded post but thought it would be best to get out as much info as possible.
Ray
FeetSteez
Postby MR2BOY23 » Wed May 11, 2011 1:30 pm
I hope there's someone on here willing to do it for cheaper than that?
I've got a exedy heavy duty clutch, but my cars not exactly standard. If you just drive the car normally, there's no reason to get an uprated clutch.
$1000 seems pretty expensive for what should be a 3-4 hour job?
The exedy clutch kit itself should only cost between 2-$300
Flywheel machining - $50
Main Seal- $30
MR2BOY23
Postby BZG Wagon » Wed May 11, 2011 1:57 pm
Why do you need a heavy duty clutch?
From my experience Toytoa clutches should easilly last upwards of 150kms easy. On this basis I'd go with a factory replacement.
BZG Wagon
Postby FeetSteez » Wed May 11, 2011 3:04 pm
Thanks for the responses so far.
As above, I'm not looking for anything heavy duty in particular. The Toyota mechanic only had the exedy clutch kits available for my model which he explained was a pretty standard kit but added about 15% more durability etc.
Just after something that has a good feel and is reliable (and relatively cheap!).
FeetSteez
Postby Mr Revhead » Wed May 11, 2011 3:05 pm
Can you ask him to show you his clutch durability measurement tool? :P
Pretty common kit to run out of!!! (I'm assuming it's a 1zz engine?)
Postby FeetSteez » Wed May 11, 2011 3:46 pm
Mr Revhead wrote:Can you ask him to show you his clutch durability measurement tool? :P
Haha yeah my thoughts exactly. I asked him whether he had anything stock standard/cheaper and he gave me the long answer to no.
Engine is 2zz.
FeetSteez
Postby Bazda » Wed May 11, 2011 4:39 pm
$600-700 is a pretty decent price.
My dads shop would charge around the same price, the clutch you would get with my dads shop is normally 30% more clamp than the stock pressure plate. They use a reputable clutch supplier.
Postby Lloyd » Wed May 11, 2011 7:25 pm
The $700 mark seems about right. Toyota are about the best price for the majority of their clutches so I wouldn't even bother with aftermarket ones too
Postby rollaholic » Thu May 12, 2011 10:57 pm
yeah TGP are pretty competitive on a lot of that service type stuff.
6-700 is a fair price, to get it cheaper you'll be looking for someone to do a home job or something.
Postby FeetSteez » Fri May 13, 2011 3:46 pm
Cool thanks for the responses everyone. Will let everyone know how I get on when I get it done in about a months time.
FeetSteez
Postby THA SHZ » Fri May 13, 2011 10:53 pm
i reckon your best bet would be to go and see barrys dad bruce and get it done , hes a great guy and he will look after you and do you a good price , cant get any better than that 8)
THA SHZ
Postby gt4dude » Fri May 13, 2011 11:48 pm
That Exeedy kit with the HD clamping kit and the full face organic clutch disc is a really nice kit, if you can get it for around $350 go for it, thats about trade price for such kit, otherwise they retail $600+ then forget it.
Toyota quoted you $950 thats retail on the clutch and $100 an hour labour.
Stink guys eh
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
