Help with 20v 4age condenser?
Postby AE111_JAMES » Thu May 12, 2011 9:07 pm
The small box next to the coil pack, can someone please tell me if this is a condenser, if so is it necessary to run the engine? I have something else similar but not the exact thing.[/img]
AE111_JAMES
Postby 1I1 » Thu May 12, 2011 9:21 pm
The ignitor?
TRD Clicky >>Here
1I1
Postby AE111_JAMES » Thu May 12, 2011 9:46 pm
nah, that two wire plug there.
not too sure what it is and what it's used for.
AE111_JAMES
Postby sergei » Thu May 12, 2011 9:50 pm
It is a condenser, and any ignition/points one will do.
Postby Burning Angel » Thu May 12, 2011 10:02 pm
in an electronic ignition system it helps suppress emi that could interfere with the ecu, on an engine with points it reduces arcing across the points gap.
without one on a points system the contacts would be erroded very quickly.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Re: Help with 20v 4age condenser?
Postby matt dunn » Thu May 12, 2011 10:20 pm
AE111_JAMES wrote: can someone please tell me if this is a condenser, if so is it necessary to run the engine? I have something else similar but not the exact thing.[/img]
The engine will run without one,
as in if you unplug it the car will still drive normal.
But is generally accepted that they are required for long term use.
Postby AE111_JAMES » Thu May 12, 2011 10:26 pm
thanks for your help guys.
this is what I have, and I just need to re-wire this to my new loom plug?
[img][img]http://i1234.photobucket.com/albums/ff411/ilimin8u/P1020571.jpg[/img][/img]
AE111_JAMES
Postby jondee86 » Sun May 15, 2011 11:51 am
Yes, that should work. The condenser is mainly there to suppress electrical "noise". You have the earlier version of the same thing
in your hand.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby AE111_JAMES » Sun May 15, 2011 4:06 pm
Thats awesome thank you very much mate, can now carry on with the conversion :)
AE111_JAMES
