Brake issues...
Brake issues...
Postby amdeman » Tue May 31, 2011 7:59 pm
Unusual situation with the brakes on an NZ new 1995 AE101 Corolla with ABS.
The brakes work (averagely), that is easy enough to compensate for, though when sitting (engine running) the brake pedal fades to the floor (with slight pressure) the brakes still on enough to hold the car from moving.
So far, to try and alleviate the issue, have replaced the brake master cylinder (new aftermarket one), the fluid, the front pads, flushed the entire system repeatedly, even reset the rear drums and handbrake.
Checked the vacuum, when unplugging the air hoses there is HEAPS (LOUD hissing noise once pulled off the booster).
How often do the one-way-valves on the vacuum side of things give out?
HELP!
Any ideas / suggestions as to what is going on?
All help greatly appreciated.
amdeman
Postby CXGPWR » Tue May 31, 2011 8:57 pm
If you have replaced the master cylinder., i believe the problem will be in your abs unit
CXGPWR
Postby amdeman » Tue May 31, 2011 9:36 pm
CXGPWR wrote:If you have replaced the master cylinder., i believe the problem will be in your abs unit
Any idea as to what it could be?
Say an issue with an air-lock (the easy, and cheap option)?
amdeman
Postby CXGPWR » Tue May 31, 2011 9:56 pm
I wouldnt have thought so, i would be pointing the finger at the valve assembily in the abs unit itself, the not so cheap option.
CXGPWR
Postby amdeman » Tue May 31, 2011 10:01 pm
CXGPWR wrote:I wouldnt have thought so, i would be pointing the finger at the valve assembily in the abs unit itself, the not so cheap option.
Or Pick a part?
Must be an ABS unit there amongst the yards...
amdeman
Users browsing this forum: Bing [Bot] and 29 guests
