gepsk8 wrote:sound like non charging in turbo timer mode. might be way it wired or gauge isnt wired, check with voltage meter.
14.6V is max charge you would be wanting. is battery flat or full charged?
gt4dude wrote:my battery is in the boot with a distribution block with voltage readout hanging onto the side of the box, directly wired in to the batt.
Key on 14.6, Key off 13 and dropping.
Yeah apparently it was a pretty bad ground, fixing it solved alot of little irritating electrical quirks. even coincidentally some idle (operating temp) smoke cleared up.
so all good to run a direct fused 4ga wire from alt to batt? or it will drain batt??
gt4dude wrote:Yeah 14.6 while running. So the alternator line doesn't go through a relay which my turbo timer isnt wired to keep on??
Malcolm wrote:the problem isn't the output from the alternator, it's the field supply that makes the alternator function. Fix the turbo timer wiring, rather than trying to bodge up a fix
One of these is a car alarm, is it a) or b)?
a)
b)
gt4dude wrote:Malcolm wrote:the problem isn't the output from the alternator, it's the field supply that makes the alternator function. Fix the turbo timer wiring, rather than trying to bodge up a fix
I'm not a qualified alarm installer, the turbo timer is an addon chip to my Dynatron alarm, I need to see them??
Because they also did another weird thing, my Window Lock button on my door... it switches off my alarm functions.. cant lock the car, cant start the engine, siren remains silent, nothing at all.. (if pressed while driving car shuts down) But I traced it back to the plug in the interior loom going to the fuses by the driver kick panel and it all looks stock and unbutchered.. wtf?
