AE111 Airbox differences
Postby clarkbzg » Wed Jun 15, 2011 7:45 pm
so just replaced the pod filter setup in my 1997 carib BZ touring with the factory setup. The black plastic pipe which runs from the airbox towards the headlight was still there so did not bother getting that too, but when I fitted the airbox the plastic pipe is a smaller diameter than the opening in the airbox for it.
Has anyone come across this before?? I figured it would all be the same.
Thanks guys, Nick
ex 95 levin bzg, ex 1989 EF9, 97 bz touring carib
clarkbzg
Postby Bling » Wed Jun 15, 2011 8:14 pm
You sure it was from the same model of car?
Postby clarkbzg » Wed Jun 15, 2011 8:16 pm
yeah came out of another bz carib. I think it was a 1998 model it came out of. I would have thought they would still be the same??
clarkbzg
Postby RobertC » Wed Jun 15, 2011 8:19 pm
setup look like this?
isn't the bottom connection triangle ish shape?[/img]
RobertC
Postby clarkbzg » Wed Jun 15, 2011 8:43 pm
oh yeah its the bottom triangular bit which is smaller than the triangular opening on the airbox
clarkbzg
Postby 1I1 » Thu Jun 16, 2011 1:40 pm
Levin/Trueno's have a larger triangular opening than Corollas and Caribs from what I remember. I used the lower half off a 4AFE Corolla as it also had the correct moulding for where it bolts to gearbox mount.
Quite possible later BZ Carib has a larger opening though?
TRD Clicky >>Here
1I1
Postby Kiwi-Corolla » Thu Jun 16, 2011 1:52 pm
Toyota slightly changed the intake size in 1999. You'll need to get one from a pre-99 model in order for it to be compatible.
Kiwi-Corolla
Postby clarkbzg » Thu Jun 16, 2011 7:47 pm
ah well thats confusing.
The airbox was from a 98 carib, but did notice that it did not want to bolt up correctly to the mounts too. Seems like I'll need to investigate that one a bit more and try other parts then
Anyone have a complete intake going then??haha
clarkbzg
