Stott69 wrote:
trdtrueno wrote:to make things worse is the water pump is poked so ill have to get round to replacing the seal in the back of that as the water just drips constantly from that.
trdtrueno wrote:yea, have been told its most likely something to do with the distributor so ill get round to that soon when i have the time, its going to be a mish as its under the whole intake manifold.
as for bgh, i took off the exhaust manifold heat sheild and the side of the block is wet most of the time and pretty sure its #1 cylinder where the problem is., and to make things worse is the water pump is poked so ill have to get round to replacing the seal in the back of that as the water just drips constantly from that.
as for getting a corolla, ill be looking for something once i get rid of this, only have it as i was given it by a family member, so no complaints there.
Users browsing this forum: No registered users and 47 guests
