4age silvertop smoking black smoke from exhaust.
Postby KIPH8N » Sun Jun 26, 2011 10:25 pm
My 4age silvertop is smoking black smoke. But not much when accelerating.
What could be the problem?
KIPH8N
Postby Dell'Orto » Sun Jun 26, 2011 10:26 pm
Leaky injector maybe, maybe its blocked?
Postby KIPH8N » Sun Jun 26, 2011 10:39 pm
Dell'Orto wrote:Leaky injector maybe, maybe its blocked?
How do i check? 8O
KIPH8N
Postby Mr Revhead » Sun Jun 26, 2011 11:35 pm
So you nail it and over like 5k rpm it's pumping out black smoke? Thats normal.
Or is it more than that?
Postby sergei » Mon Jun 27, 2011 12:11 pm
Mr Revhead wrote:So you nail it and over like 5k rpm it's pumping out black smoke? Thats normal.
Not if you replace injectors with blacktop ones.
I have fixed the "diesel like" smoke on about 5 AE101s by replacing injectors out of BTs (or facelift AE101, but much harder to differentiate).
And YES, BT injectors ARE different to pre-facelift ST.
preface-lift ST injectors are also different to facelift.
If you pull the injector out of pre-facelift and facelift, look at the business end you will immediately spot the difference in hole size and spacing. BT were also spaced slightly different to facelift.
Bot BT and facelift injectors work well. Prefacelift injectors are crap.
Postby Mr Revhead » Mon Jun 27, 2011 12:15 pm
I fixed mine by fitting a chipped ECU :lol:
Postby BZG Wagon » Mon Jun 27, 2011 1:10 pm
Agreed - I thought my BZ-T was f*cked when I bought it given the amount of smoke coming out.
Black smoke cann mean it's running rich. I hear because 4age's are highly tuned from factory, they run rich when you nail it to protect the engine from melting into a paper weight.
Should only be noticable at high revs I'd expect.
BZG Wagon
Postby KIPH8N » Mon Jun 27, 2011 8:05 pm
Black smoke comes at around 3-5. So the injectors need replacing.
KIPH8N
Postby sergei » Mon Jun 27, 2011 8:59 pm
KIPH8N wrote:Black smoke comes at around 3-5. So the injectors need replacing.
Depends how much of black smoke: if it smokes like 2.4 Diesel Hilux towing a boat up hill - then yes.
Postby MAGN1T » Mon Jun 27, 2011 9:08 pm
It means that it's broken.
If it's broken then you need to do a proper diagnosis, not just swap parts using guesswork.
As for the "leaking injector".....that only happens on US forums.
Best place to start would be to have a look at the plugs, that way you'll know if it's one cylinder running rich or all of them, you're not going to have 4 injectors break all at the same time?
Maybe pull fault codes at the same time just to rule out other possibilities.
Then you could always flow test your injectors? not hard to do if you've got a bit of imagination.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Mr Revhead » Mon Jun 27, 2011 10:05 pm
Is is running at normal temperature?
Test the ECU temp sensor
Users browsing this forum: No registered users and 46 guests
