Removing Decals
Removing Decals
Postby Mr Revhead » Mon Jun 27, 2011 5:21 pm
Ok so not a Toyota, or even a car....
But my new bike frame is a really cool satin black. And has ugly decals on it.
They are pretty thin, can hardly feel the edge and can't get a peel started.
Any suggestions to a product or technique to removing them without harming the paint?
Postby Bazda » Mon Jun 27, 2011 5:29 pm
Apply heat?
Heat gun.
Postby gasman » Mon Jun 27, 2011 5:40 pm
is it a sticker or something like on model kit sets where you soak the sheet in water to lift off the paper backing then transfer to the model?
"What can possibly go wrong?"
gasman
Postby Mr Revhead » Mon Jun 27, 2011 5:42 pm
Yeah I suspect it's a heavy duty version of that rather than a sticker.
So not sure it heat gun will work.
Are transparent and very thin. Can't peel them
Postby 2LTR Rona » Mon Jun 27, 2011 5:48 pm
if its anything like the decals I had to remove off my moutain bike years ago, then yes they are a sticker & the stuff on the back of them sticks like shit to a blanket.
Like Barry has suggested, I would try carefully lifting one corner (not scratching frame paint) & applying heat either via a heat gun or hairdryer to slowly heat up the glue underneath while at the same time gently peeling back the decal.
I have used the above method YEARS ago on a bike frame, however saying that they could quite easily changed what they used for them between way back then & now.
2002 Altezza, 1974 KE25
2LTR Rona
Postby Guss » Mon Jun 27, 2011 5:54 pm
ammonia, let it soak peel off
Guss
Postby Mr Revhead » Mon Jun 27, 2011 5:57 pm
Nah definitely not oldschool style stickers.
Not really keen to put bleach on it :!:
Postby Bling » Mon Jun 27, 2011 6:12 pm
Desolvit perhaps? Lost my bottle somewhere in the garage otherwise i'd let you know if its safe on paint or not :oops:
Postby Brawler » Mon Jun 27, 2011 10:16 pm
Just grow finger nails g
zing! Sig got nuked. Sorry bout that.
Brawler
Postby h8wrxs » Mon Jun 27, 2011 10:39 pm
i used a shitload of degreaser on my bmx to get the stickers off when i painted it
(i painted my bike the same blue as my trueno with the leftover paint haha its pimpin)
h8wrxs
Postby matt dunn » Mon Jun 27, 2011 11:01 pm
not stickered then clearcoated over the top of it all is it?
Postby LEAKER » Tue Jun 28, 2011 4:54 pm
If it is a sticker then use eucaliptus oil to remove the sticky residue. If its a plastic decal or sticker then heat should be the answer to remove the primary part.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Users browsing this forum: Google [Bot] and 25 guests
