1jzgte and 2jzgte pistons/rods the same?
Postby Titties » Wed Jun 29, 2011 6:44 pm
heya,
i'm looking to purchase some pistons, rods and cams for a VVTi 1jzgte.
There are almost no listings for these items.
Are they the same as the 2jzgte?
e.g. eagle, JE and CP do not list a 1jzgte piston or rod.
Cheers, Mike
'98 RS200 Altezza - SOLD
'96 Mitsi Mirage, 11.12 @ 124mph (200kph)
Titties
Postby Titties » Thu Jun 30, 2011 4:43 pm
bump
Anyone??
Titties
Postby Mr Revhead » Thu Jun 30, 2011 5:03 pm
Bore is the same so a good chance the pistons are interchangeable.
I'm sure a JZ geek will know if the pin heights etc are the same.
The stroke and deck heights are completely different so rods will be different.
as shown here:
http://www.supraforums.com/forum/showth ... s-and-Rods
Postby strx7 » Thu Jun 30, 2011 5:20 pm
the crown or pin to top height is different in them, they can be used though, if you put 1J pistons into a 2J you will have higher compression, 2J into 1J you'll have lower compression
Postby Mr Ree » Thu Jun 30, 2011 6:36 pm
Does the 1JZGTE slug have the provision for oil squirters?
wak thud gush!
Mr Ree
Postby strx7 » Thu Jun 30, 2011 7:24 pm
pretty sure they do
Postby Si » Thu Jun 30, 2011 8:13 pm
Yep 1jzgtes have squirters.
From memory you need to go bling for rods..... jun, greddy, carillo,
Current: , '96 SubaruImpreza
Si
Postby spencer » Thu Jun 30, 2011 9:41 pm
What kind of beans are you looking at making?
There's stock short block 1jz cars in the 10's, that's in a pretty heavy car too. So are you looking at making over 6-700hp?
something like these are the cheapest rod wise
http://www.modyourcar.com.au/spool-hbea ... zgte-p6181
I'd go head work, cams, decent ECU & turbo before cracking the bottom end open
ms63 crown
spencer
Postby Titties » Thu Jun 30, 2011 10:58 pm
Titties
Postby RomanV » Fri Jul 01, 2011 12:57 am
I know it's not the same motor, but with the 3S motors the VVTI versions have a completely redesigned head compared to pre vvti, with a smaller combustion chamber.
Meaning pistons are incompatible between VVTI or non VVTI.
Might be something worth checking before buying some bits!
