Broken Starlet! Any advice appreciated
Postby ke2nv » Wed Jun 29, 2011 6:58 pm
Hey, Ive been running around in a 86 Starlet, 1300 EFI, hasnt missed a beat until just the other day. I noticed it was hesitating and spluttering as I was driving down the road, definately not at full power. It got worse and worse until foot flat i was doing 1500 rpm. The whole car was jolting and missing. I left it on the side of the road overnight, came back in the morning to tow it.
Before we towed it, I started it up, and it ran absolutely fine, drove it down the road and about 30 seconds later it died again, this time back firing from the air intake, and hesitating and coughing.
Hopefully someone on here would know what might cause this? Seems to be mainly a problem when the engine gets warm, Maybe a sensor? Any help would be appreciated. Cheers, Randal
Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
World's best description of "How To Drift".
ke2nv
Postby siren676 » Wed Jun 29, 2011 7:06 pm
So its an ep70 with a 2e-telu?
siren676
Postby gepsk8 » Wed Jun 29, 2011 7:14 pm
faulty fuel gauge? put some gas in it?
when stops check for spark? yes then remove plug check for gas on end?
O272754663
gepsk8
Postby Lloyd » Wed Jun 29, 2011 8:27 pm
I'd be guessing more EP71 with a 2E-E.
Checked plugs, leads, etc etc?
Postby ke2nv » Wed Jun 29, 2011 8:30 pm
Yep EP71 with 2E-E
The plugs all look fine, no oil on them or anything. Leads are all on properly.
ke2nv
Postby LEAKER » Wed Jun 29, 2011 8:49 pm
sounds like the fuel pump just shit itself. Occasionaly they run then die before crapping themselfs completely. Run the car untill it dies then take the fuel hose off and check if there's any fuel running through it.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby 85AW20v » Thu Jun 30, 2011 9:32 pm
Or a blocked fuel filter....
See ya
Simon
85 MR2 20v
85AW20v
Postby ke2nv » Thu Jun 30, 2011 10:16 pm
Okcheers il check those tomorrow
ke2nv
Postby LEAKER » Fri Jul 01, 2011 8:51 pm
cool. let us know how you get on i'm quite interested now.
LEAKER
Postby ke2nv » Thu Jul 14, 2011 6:08 pm
It was a rooted fuel pump!
ke2nv
Postby LEAKER » Thu Jul 14, 2011 6:53 pm
FIGJAM
LEAKER
