KE30 Alternator
KE30 Alternator
Postby brentm » Tue Aug 02, 2011 6:30 pm
i have a standard 30Amp alternator on my 4K, the Amp is drawing to much power for my Sub, is there a easy solution to fix this problem, i have disconnected the amp for now as my Battery keep going flat. Cheers.
brentm
Postby whynot » Tue Aug 02, 2011 8:49 pm
you could either find a bigger alternator or run a second battery with one of those automatic change over charger units fitted to it. most alternators I know of are good for more than 30amps these days and would be the best option
whynot
