redline racer wrote:Can you get aftermarket new Lcd screens?
You can get replacement screens for the AC unit, but not the EMV
redline racer wrote:the cars iam looking at have done approx 160-220km. Most seem to have airbag suspension? Is it a straight swap back to conventional struts & how hard are they to obtain? Im guessing replacing airbag parts will be mega expensive.
Yes, new struts are available from Toyota and JZA80 parts fit to some degree, and it depends on what you want from the car, a Soarer with new Airbags and bushes all round has one of the most comfortable rides I've ever experienced.
FWIW, even if the Airbags are still holding air, the dampeners are going to be shot
holden_fan2005 wrote:Note: They tend to chew the gas and tyres though.....
You might want to check your alignment/LCA bushes
