rollaholic wrote:no more than 4-500 i would have thought for a good runner.
Dell'Orto wrote:If its a smallport, you can get good power out of them - even stock they have more low end torque than a 20v.
ee904age wrote:Looks to me like its a Bigport, not really an ideal base without a lot of work. Better off with a smallport although they're getting harder to find these days, or as mentioned, a silvertop.
matt dunn wrote:rollaholic wrote:no more than 4-500 i would have thought for a good runner.
a complete smallport is probably worth more than that,
and with the Quads and adapter it definatly is worth way more than that.
RedMist wrote:Smallport is a better high dollar development engine.
Silvertop yields little through tuning. My silvertops were 122 and 123 WHP. Blacktop 126. Supersmallport 178whp (smallport with ports reduced in size, injectors shifted, quads, shim over bucket, and forged internals. )
I did have a cammed, bumped compression 20 valve that developed 146whp.
The problem with 20 valve engines is the centre valve. Which way do you swirl the charge? and how do you bump compression without having a piston that looks like a tripple tittied porn stars implants? Flame propogation across the charge must be next to impossible!! Let alone the detonation points created across it's peaks.
TRD Man wrote:If I had $4 ~ 5K to spend I'd be looking at gearing, throwing away the liteace diff and installing a T series with LSD, suspension and tyres. Attention to those things will actually reap benefit.
Mr Revhead wrote:Silvertop with a link and a good intake and exhaust will be the way to go. If the budget allows maybe some rally cams from kelfords or Franklin's etc.
A decent tune on a silvertop gains a fair bit of power. Plus easier to find and much cheaper than a smallport.
KinLoud wrote:I drove it - no torque below 3000rpm started pulling at 4000rpm and was mighty above 6000rpm
Users browsing this forum: Bing [Bot], Google [Bot] and 38 guests
