power steering conversion ms65 crown
Postby LEAKER » Fri Aug 19, 2011 8:06 am
Has anypne had any experiance with this. Thinking about purchasing a 1974 ms65 crown but if I want the mrs to drive it then really need a power steering conversion. I'm almost certainly going to be putting a 1jzge in it so I could probably use most of the gear that would come with that I'm guessing?
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby deaf_rattle » Fri Aug 19, 2011 12:13 pm
if you are going to convert to a 1jzge.. why not go 2jzge? probably very similar cost to do, but so much more potential further down the track.
Postby LEAKER » Fri Aug 19, 2011 1:26 pm
Only looking for a economical reliable engine. I was thinking of a 2jzge but I really only want economy with enough power to drag the heavy tank along.
LEAKER
Postby Grotty » Fri Aug 19, 2011 6:07 pm
Hey pretty straight forward, early hilux power steering box bolts in and make lines to the 1jz/2jz power steering pump.
Grotty
Users browsing this forum: Google [Bot] and 30 guests
