Injectors not clicking
Postby escortman » Sat Aug 20, 2011 1:01 pm
ok so found the problem with my supra not starting was that only 2 injectors were actaully opening, (pulse is fine etc) so took em out and blasted a bit of air through em. 4 work fine now but 2 dont even click but resistance is same as rest are they toast? who has some 2jzgte kicking around? cheers
4x4 toyota blizzard offroader
escortman
Postby Rick » Sat Aug 20, 2011 2:09 pm
I dont think blowing air through them would have done much, you are better to have them all ultrasonically cleaned and flow tested and while your at it fit new O rings and filters etc to the injectors.
Postby escortman » Sat Aug 20, 2011 2:22 pm
na the air managed to clear out the crap and they now unblocked
escortman
Postby AE82 FXGT » Sat Aug 20, 2011 4:31 pm
Rick wrote:I dont think blowing air through them would have done much, you are better to have them all ultrasonically cleaned and flow tested and while your at it fit new O rings and filters etc to the injectors.
+1 shouldn't even cost that much to do this, and flowtesting will show up any faults.
AE82 FXGT
Postby matt dunn » Sat Aug 20, 2011 5:57 pm
I am pretty sure that I have a set of 6,
and can do ultrasonic cleaning and testing too.
Can possibky do a deal trading your 6 + cash for my 6 good ones,
as I really only need a set of 4 for what I want, and should be abkle to make 4 good ones from your 6.
PM me if your keen to do a deal.
Matt
Postby RedMist » Sun Aug 21, 2011 7:52 pm
escortman wrote:na the air managed to clear out the crap and they now unblocked
You're attempting to blow air through a closed pintle. You're not going to clean them that way. In fact you may have forced some of the crud past the filter and into the injector pintle.
Your injectors must be ultrasonic cleaned and flowed to ensure you don't run one (or more) cylinder lean. It'll save you an engine rebuild.
I'd take up Matt's deal. Whenever I've had my injectors cleaned and flowed I've had to take two sets in order to ensure I got one set back that flowed close enough to use.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby escortman » Sun Aug 21, 2011 7:55 pm
Oh i hooked 12v up to them to get them to open whilse had the air on them, will defiantly getting them flow checked etc yeh pmd him already
escortman
Postby sergei » Sun Aug 21, 2011 9:04 pm
Only do that (apply 12v) to high impedance injector, if you apply 12V to low impedance you will burn it out. Air is not going to do anything if you are normally forcing fuel on normal usage.
Users browsing this forum: Bing [Bot] and 6 guests
