sw20 starter motor removal
Postby Grrrrrrr! » Wed Aug 31, 2011 9:40 pm
Two bolts and a gentle tap with a soft face should get it off right?
Just asking cos i've removed two bolts, hit it with WD40 and given it a few not so gentle taps and the little bugger hasn't moved more than 1mm. Is there some hidden bolt or a trick to it?
Grrrrrrr!
Postby Dell'Orto » Wed Aug 31, 2011 9:45 pm
Yup, just two bolts. Might be catching on the clutch slave if its on a slight angle
Postby Grrrrrrr! » Wed Aug 31, 2011 9:46 pm
Cheers, will go unbolt the clutch slave and if its still stuck resort to some more forceful persuasion.
Grrrrrrr!
Postby Dell'Orto » Wed Aug 31, 2011 10:06 pm
Shouldnt need to unbolt it, just pull the starter straight back and it ought to come off. Might just need a wiggle while you're pulling it
/inb4thatswhatshesaid
Postby Malcolm » Wed Aug 31, 2011 11:16 pm
not sure which direction you've been hitting it, but try hitting it on the mounting flange in a direction that'll make it rotate in the circular hole it's in/about the axis of the starter gear.
Postby Grrrrrrr! » Wed Aug 31, 2011 11:24 pm
Yeah, tried the rotational thing, in the end just required using a screwdriver as a wedge behind each ear of the starter flange to jack it out. Amazing how effective 10 years of corrosion can be.
Grrrrrrr!
