Water through diesel system. further issues.
Postby gleem » Sun Sep 04, 2011 8:45 pm
following my last thread. With the hard injector hoses of the diesel pump there is creamy white stuff that comes out the injector pump that doesnt mix with the the rest of the fluid(diesel) im assuming this is water. I have cranked it for about 5 minutes in total and it just wont stop coming, Is there a better way?
More worring is that the 1,2 and 3 cylinder lines get a good high pressure squirt out the outlet but the number 4 is only half the pressure.
im now assuming my pump is stuffed.
gleem
Postby iOnic » Sun Sep 04, 2011 9:53 pm
^Basically what you were told in the last thread. Pull the pump off and get it checked. Water $&#$% injection pumps - just the way it is
