Curren Lsd shaft vs 16x, 18x non lsd shaft lenght
Postby CelicaGT8 » Mon Sep 05, 2011 7:52 pm
96ish Curren Lsd shaft vs 16x, 18x non lsd shaft lenght
Just finished mounts etc, put in shafts and the dam drivers side outer shaft is to long!
Are the curren lsd outer r/h shafts longer than the 16x and 18x non lsd shafts?
bugger! The last thing needed to get it on the ground, grrrrrrr
CelicaGT8
Postby Infinite » Mon Sep 05, 2011 9:03 pm
st202 lsd shafts. problem solved :P
Lots
Infinite
Postby CelicaGT8 » Mon Sep 05, 2011 11:48 pm
Thaught they would be the same as the curren ones?
CelicaGT8
Postby CelicaGT8 » Tue Sep 06, 2011 7:43 pm
is a curren wider or something? anyone got a shaft?
CelicaGT8
Postby ®usty » Wed Sep 07, 2011 7:31 pm
an LSD Curren would have superstrut, could be the reason why the shaft/s are longer
®usty
Postby CelicaGT8 » Fri Sep 09, 2011 4:47 pm
Ahh, yea it did, thats it
CelicaGT8
