1G into 4 cyl xA6#?
1G into 4 cyl xA6#?
Postby Hachiroku » Tue Sep 06, 2011 7:51 pm
Anyone here put a 1G into a 4 cylinder xA6# chassis eg AA60, TA63, RA63, SA60? Any idea what the simplest way would be? Would a GA61 cross member fit or is it too wide?
Hachiroku
Postby matt dunn » Tue Sep 06, 2011 8:13 pm
We have an SA60 with a 1GGTE in it, but it is set so far back it's almost mid mounted, so any info would probably be useless as everything is modified.
Postby Hachiroku » Tue Sep 06, 2011 9:22 pm
Yeah probably a bit more extreme than what I'm considering. I think the Aussies use slightly modded factory mounts when putting them into RA63s. Mine's an AA60.
Hachiroku
