sergei wrote:Free to correct me if I am wrong (above is from memory)
sergei wrote:+B is the permanent 12V supply for ECU (comes off 15A EFI fuse).
matt dunn wrote:sergei wrote:+B is the permanent 12V supply for ECU (comes off 15A EFI fuse).
You would think that but you are wrong again, lol.
BATT is the batt feed to the ECU,
+B is the ignswitched feed and is the correct one to connect to.
magweal wrote:Ok kool that should help thanksDoes anyone no what switch on the side of the ignition barrel does
Users browsing this forum: Bing [Bot] and 6 guests
