MLS head gasket prep
Postby Grrrrrrr! » Thu Sep 15, 2011 4:55 pm
How smooth does the head and block need to be to get a good seal with a MLS head gasket?
Just picked my head and block up from machining and the machinist says its all good to go, but it feels pretty rough to me.
Grrrrrrr!
Postby Malcolm » Thu Sep 15, 2011 5:44 pm
I found a surface roughness guide once but buggered if I'd remember where. You could always lovingly sand them with some wet/dry and something very flat. For what its worth I was concerned when I got mine done but it seemed to seal fine.
Postby Grrrrrrr! » Thu Sep 15, 2011 5:48 pm
Yeah, I have a set of parrallels around somewhere so i could hit it up with some 400grit to knock it down. It just adds more work that i'd rather skip.. Sanding, cleaning. cleaning, more cleaning. Grrrrr!
Grrrrrrr!
Postby Dell'Orto » Thu Sep 15, 2011 7:42 pm
NZ Gaskets wrote:Laminated (multi layer) steel type gaskets with rubberised coatings - less than 0.50 micrometers RA
Laminated (multi layer) steel type gaskets without rubberised coatings - less than 0.75 micrometers RA
So fairly smooth
Postby Malcolm » Thu Sep 15, 2011 8:07 pm
So fairly smooth
The machine shop I got to do mine had surface finish sample cards to allow a comparison to be made to determine the finish quality, might be worth seeing if your machinist has some of those you can check
Postby rx7guy » Thu Sep 15, 2011 11:13 pm
Could try copper spray?
The torque band is wide and the road is narrow
rx7guy
Postby Grrrrrrr! » Thu Sep 15, 2011 11:55 pm
So fairly smooth
Seems weird to me that the one without the rubberised coating can handle more roughness. Thinking i'll just go with the composhit gasket if it measures up too rough.
Grrrrrrr!
Postby Malcolm » Fri Sep 16, 2011 12:59 am
I'll be keen to unsell mine if you change your mind :lol:
Users browsing this forum: Bing [Bot] and 6 guests
