E series to A series?
Postby rollaholic » Wed Sep 28, 2011 8:56 pm
anyone happen to know if a 4AGE uses the same mounting points on the body as a 2E in corollas? AE101 in particular (or EE101 i guess it would be)
ie, does a 4AGE bolt into a 2E powered corolla with the appropriate mounts etc, or are the bodies different
Postby iOnic » Wed Sep 28, 2011 9:10 pm
Not a bolt in swap. Mine has 4A mounts welded to the chassis with the 2E mounts cut out and the bottom crossmember added (2E to 4A) need cert for it too ofcourse.
Postby xsspeed » Thu Sep 29, 2011 9:16 am
Crossmember mounts could be the same? Cambelt mount is definately different
Users browsing this forum: Bing [Bot] and 29 guests
