4age oil warning light on..?
Postby dxtawagon » Tue Oct 25, 2011 9:44 pm
hey,
recently put a replacement 4age bigport into my ae82 (NZ new) GT.
it runs fine but the oil light stays on almost all the time.
the only time it goes off is when the cars warm and the idle drops right down, then it flickers....?
any ideas? the new engine is out of aw11 and the past owner said the oil light was not on in his car?
Im pretty sure i hooked it up correctly.
Any help appreciated.
dxtawagon
Postby Alex B » Tue Oct 25, 2011 9:59 pm
AW11's have an oil pressure gauge by the look. Rip that sensor out and replace it with a sensor from a car with no gauge.
Postby evil_si » Tue Oct 25, 2011 10:03 pm
Put your old switch / sensor in
evil_si
Postby Lloyd » Tue Oct 25, 2011 10:06 pm
As above, chances are the oil pressure sender is a big round unit which is actually for an oil pressure gauge. What you're after is an oil pressure switch which is very small in comparison.
Postby dxtawagon » Wed Oct 26, 2011 6:19 am
sweeeet, thats easy to sort out.
dxtawagon
Postby Allister S » Wed Oct 26, 2011 10:23 am
I too can confirm this is your issue. I ran a AE82 with a AE92 oil pressure gauge pick up for years - when the oil light goes out with any revs on PANICK. Would flicker at warm idle.
Even better get a decent oil pressure switch that comes on at 15 or 20psi, rather than the factory ones that only come on once your engine is dead (only 2psi or something)
Cheers, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Users browsing this forum: Bing [Bot] and 28 guests
