AE82 Clutch Master Cylinder
Postby Mike228 » Wed Oct 26, 2011 12:45 pm
Does anyone know if these are rebuildable?
Mine is leaking fluid (slowly), but is still functional, so I'd rather not go poking around to try and find out incase I make it worse.
I expect it is just a seal, but are they be disassembled?
Cheers,
Michael
Mike228
Postby Mr Revhead » Wed Oct 26, 2011 12:56 pm
Yes they are with a seal kit.
However if it is corroded in the barrel it will need honing and possibly sleeving.
In which case a new one would probably be a better idea.
Also finding a seal kit might be tricky, if you know a brake shop though they will stock various seals.
