Need help identifying diff head, U series?
Postby Di » Wed Nov 09, 2011 6:50 pm
Got a diff head I want to identify, has 8 bolt hole for the crown wheel/ring gear.
some measurement I got:
(centre to centre) distance between 2 bolt hole that next to each other is approx 47mm
(centre to centre) distance from 1 bolt hole to the other one on the opposite side cross the axle hole is approx 125mm (PCD)
diff head bearing seat outer diameter approx 42mm
crown wheel/ring seat diameter approx 103mm ?
Can't really measure the actual axle size without the right tool, but with ruler and wide oppened eyes I'd say between 22mm and 23mm?
Is there anywhere else I need to measure to help identifying?
I only have the diff head, nothing else...
Daily driver: BOMEX AE111 LEVIN BZ-G
Projects: 83' Zenki AE86 TRUENO GT-APEX, 85' Kouki AE86 TREUNO GTV
My Trademe listingsPM me if keen on anything and I'll do a better deal.
Di
Postby Dell'Orto » Wed Nov 09, 2011 7:12 pm
Pinion flange PCD is easiest way to tell
http://www.toycrazy.net/index1.html
Postby Di » Wed Nov 09, 2011 7:19 pm
Dell'Orto wrote:Pinion flange PCD is easiest way to tell
yea got that page in the bookmark, problem is I only have the diff head nothing else :roll:
Di
Users browsing this forum: Google [Bot] and 23 guests
