surge tank lift pump
Postby Anth_555 » Fri Nov 18, 2011 2:52 pm
is it ok to use a high presser pump to feed i surge tank ?
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby d1 mule » Fri Nov 18, 2011 4:34 pm
yep never had any porolems
d1 mule
Postby Grrrrrrr! » Fri Nov 18, 2011 5:06 pm
With no restriction in the output line it won't generate high pressure, just lots of flow. Might be worthwhile putting a resistor/PWM circuit in to slow it down a bit and cut power wastage/fuel heating.
Or a float switch in the top off the surge tank with a timer so it runs once the fuel level drops below the float switch and keeps running for 10secs after switch closes again to top it up.
Grrrrrrr!
Postby Anth_555 » Fri Nov 18, 2011 6:31 pm
i was more wondering that the pumps have a shortn life if they not under presser?
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Grrrrrrr! » Sat Nov 19, 2011 12:12 am
Probably more due to reason you have a surge tank.. fuel starvation.
In tank pumps use the fuel as lubricant and coolant. no fuel at pickup = no cooling..
Grrrrrrr!
Postby Anth_555 » Sat Nov 19, 2011 5:51 am
oh ive go an extrnal pump to feed the tank anyways
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby matt dunn » Sun Nov 20, 2011 6:15 pm
Anth_555 wrote:oh ive go an extrnal pump to feed the tank anyways
It's the fuel surge that kills the pumps, internal and external ate the same design inside.
as the rotary vane in them really speeds up when they get a bit of air,
and then when they get fuel back into them and the vanes are doing way too many RPM they can snap the drive inside them, or break the vanes.
It is hard to find something that can handle the surge but still supply high flow to keep the surge tank full.
Carb type electric pumps are best.
