Jaycar kits
Jaycar kits
Postby Mr Revhead » Mon Nov 28, 2011 11:05 am
Has anyone used the Jaycar ignition kits?
http://www.jaycar.co.nz/productView.asp ... TID=965#11
Or anything similar?
Postby whynot » Mon Nov 28, 2011 10:45 pm
looked at them but I'm not sure what is required to programme it. could be the old printer port or their hand held programming unit
whynot
Postby Grrrrrrr! » Mon Nov 28, 2011 10:58 pm
Requires KC5386 and WC7502 with all pins connected.
Handheld programmer and serial cable
Grrrrrrr!
Postby Mr Revhead » Tue Nov 29, 2011 9:03 am
So no one has actually used one?
Considering it for a project.
Postby iOnic » Tue Nov 29, 2011 6:41 pm
I've never used it personally but a guy on Starletcentral has IIRC. User name is Man Racer.
Postby whynot » Tue Nov 29, 2011 9:17 pm
i have one of their voltage adjusters and it has worked fine for years on my silver top. also have the hand held adjuster still. No problems with them that i have experienced. Just never used the ignition unit
whynot
Postby GTsedan » Wed Nov 30, 2011 8:00 am
I haven't, but I once read a very good thread where a guy used one on a carby 6cyl holden (I'll see if I can find it). You can set up separate spark maps depending on your situation (he was running petrol and LPG). For what it is (and the results I saw) I think its reasonable bang for your buck. Only downside is you have to set up your spark advance with the fiddly little hand controller.
EDIT
Bits of it are here
http://holdenpaedia.oldholden.com/EST_VK_Improvement
GTsedan
Postby Mr Revhead » Wed Nov 30, 2011 8:22 am
Sweet, cheers for that.
I reckon I'll go with one. Fun project and will increase my extremely lacking electronics skills!
