timing belts - race vs OEM
Postby NOLAW » Thu Dec 01, 2011 8:07 pm
Hey guys, pretty basic question, whats the differences between the race timing belts and the factory OEM one, and is it worth paying the extra $?
NOLAW
Postby iOnic » Thu Dec 01, 2011 8:13 pm
They're stronger which = less stretch at higher than stock RPM. Not really necessary. Stock belt will do just fine and stretching is only really a problem if triggering off the cam which can result in timing shift. And again, you have to be spinning fairly quick, all belts stretch a little as engine speed increases.
Postby jondee86 » Fri Dec 02, 2011 8:42 pm
Works on the same principle as the $95 TRD billet oil filler cap :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby DVSMOTORSPORT » Fri Dec 02, 2011 10:25 pm
Out of all the race engines Ive built and seen built (NZRC race engines etc) not a single one of them had one of those belts fitted.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby touge_ae101 » Mon Dec 05, 2011 1:24 pm
it can make a difference to the tunability of the car. as a race belt has extra reinforcing etc so won't stretch at high RPM/load. i have heard it can make as much as 3-5deg of timing at the top end which is a bit to have to account for when tuning.
but best to look at such things in perspective. extra $$ vs probably unnoticable gain. prob only be worth it on mega cutting edge engine.
touge_ae101
Postby RomanV » Mon Dec 05, 2011 3:06 pm
Or made redundant by VVTI, which can accomodate for belt stretch.
Postby MAGN1T » Mon Dec 05, 2011 5:45 pm
Do timing belts actually stretch?
How much by?
Where's the proof?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby touge_ae101 » Mon Dec 05, 2011 7:05 pm
MAGN1T wrote:Do timing belts actually stretch?
How much by?
Where's the proof?
Steve
the internet. everything you read there is the truth.
but srsly had this discussion with a mate (ONPSI) who attended one of the STM workshop thingys where they explained all this type of stuff. Lith will prob know more about it than anyone else who frequents on here.
touge_ae101
Postby iOnic » Mon Dec 05, 2011 7:09 pm
I attended the same thing as Haagen and Daniel (Lith) and yes it was pointed out (with evidence) that this happens and what effect it has on your tuning strategy. I've personally seen it plenty of times on various engines. Many ECU's can take this into account with constantly variable trigger angles eg below. You can tune around it and it's not much of a change but bear in mind that the belt does have a breaking point so if it's getting a fair bit out it's probably safer and cheaper to get a stronger belt. Doesn't have to be a bling brand, various other brands make belts with more reinforcement than stock.
http://files.haltech.com/downloads/plat ... gger_angle
"Race" belts are pretty much a case of you either need it or you don't. If there's nothing wrong with your current belt, you won't gain anything from getting an expensive "race" belt - don't waste your money. But if you have huge cams and are chewing belts after a few thousand hard kms or have a stretching issue, then there is something to gain from having one. Or you could just replace them every couple months I guess?
Postby MAGN1T » Mon Dec 05, 2011 8:30 pm
Normally when a cambelt fails, the belt itsself is intact, it's just the teeth that come off.
In fact even cambelts that run around the waterpump, when the waterpump seizes, it'll start to melt and smoke but won't snap.
Personally I think the whole "stretch" thing is a load of shyte.
The strength in the belt is normally fibreglass or for the ricer versions it's carbon fibre.
There you go, you can find anything on the interweb.
http://www.aa1car.com/library/ar594.htm
Timing chains are bad for stretching though, that's because every link is a bearing which wears, no different from bike chains which need constant adjustment.
Steve
MAGN1T
Postby iOnic » Mon Dec 05, 2011 8:35 pm
You're the expert.
Postby MAGN1T » Mon Dec 05, 2011 8:43 pm
No, I don't know anything.
But know enough about most things to know when I'm being told porkies.
I've been told plenty of porkies by persons who should know better.
I used to have a townace with a 3Y in it, the chain on that was severely stretched, you could hear it rattle.
More than likely STM got mixed up between belts and chains.
Steve
MAGN1T
Postby iOnic » Mon Dec 05, 2011 8:46 pm
MAGN1T wrote:No, I don't know anything.
I'll take your word for it.
Postby Grrrrrrr! » Mon Dec 05, 2011 8:54 pm
Oh dear, Magn1t is confusing plastic yeild with elastic yeild.
Simple fact is nothing has a youngs modulus of infinity, so everything stretches as tensile load on it is increased. So yes, even those $260 race timing belts stretch, just hopefully a lot less.
Grrrrrrr!
Postby Emperor » Mon Dec 05, 2011 9:11 pm
Seconded.
Minutes taken.
MAGN1T for president of $&#$% all.
Emperor
Postby Luke - BZG » Tue Dec 06, 2011 3:35 pm
MAGN1T wrote:More than likely STM got mixed up between belts and chains.
Steve
Yea, I bet a tuning company like STM hosted a course full of people who know a thing or two about tuning, and discussed more in-depth concepts about tuning and engine performance and not a single person realised a huge mistake like that.
Luke - BZG
Postby Mr Revhead » Tue Dec 06, 2011 4:43 pm
Oh dear.
The thing that will apply to what belt you need is the state of tune of your engine. As mentioned unless it is a wild beast a stock one will be more than fine.
I would be keen to see examples of proven belt stretch causing issues. Would be interesting to see at what level it became an issue.
Postby matt dunn » Tue Dec 06, 2011 8:34 pm
I can see that an engine where all the position sensing is done from a camshaft like the 4AGE's or the Nissan RB engines and they done have any actual sensor on the crank,
that there will be enough, lets call it "stretch" to make the timing a few degree's out.
if a few degrees of timing change makes a difference to your engine or not is another matter.
Postby NOLAW » Wed Dec 07, 2011 1:09 pm
the engine im running is a very similar setup to the 7agte in barrys levin, although because its going into a KE20 i wont be planning to run it on 300+ kw all day everyday, thats not to say i wont wana take it up to there at some stage though just to see how it does
NOLAW
Postby loudstealthGT-Four » Wed Dec 07, 2011 6:41 pm
Steve
Then please stop posting stuff in the tech section :lol:
loudstealthGT-Four
