[slaps forehead]BZG|Bling wrote:For the door sensor, have you tried swapping them over? Try that if you haven't to eliminate the sensor itself being at fault.
Garreth27 wrote:this may seem stupid but if all the problems are from the same door, thought about replacing the whole door?
strx7 wrote:Garreth27 wrote:this may seem stupid but if all the problems are from the same door, thought about replacing the whole door?
the door closed sensor is on the body, not in the door.......
siren676 wrote:They do have a light chime, its on a little chip on the back of the dials. Just get the drivers for sensor fixed and it'll work.
Nah, not a stupid question.Garreth27 wrote:this may seem stupid but if all the problems are from the same door, thought about replacing the whole door?
crispy'86 wrote:So if it's catching on the exterior door trim, the one you prised to show the green retaining clips, there are a few options.
1) Perhaps eliminate this by removing it, raising the window and down to see if it operates smoothly.
3) Get a replacement and see if that works
BZG|Bling wrote:Could always try lubing the trim up when you have it out.
