Turbosmart boost tee noise
Postby Stott69 » Wed Jan 04, 2012 5:24 pm
I dont seem to be able to get the boost up to above .6 bar at the moment, so have presure tested the intake. With this I have found my BOV is leaking a little (might be adjustable?) and my boost tap make a weird noise.
http://youtu.be/TjP9FaWpmUE
Should it be doing this?
And has anyone dealt with PROF BOV's before?
Stott69
Postby Crucible » Wed Jan 04, 2012 7:49 pm
The boost tap will leak as thats what it does "bleeds air". The BOV should be fully closed 'under boost' as you will have pressure ontop of the diaphram assisting it to close untill the throttle closes then it will see vacuum. The 50mm one on my car piss's around a bit at idle but fully closed under boost etc..
I take it you have adjusted the tap further? The BOV you have is adjustable also..
Crucible
Real Life Mechanic
Postby Quint » Thu Jan 05, 2012 7:47 am
Check your boost gauge.
Quint
Postby Stott69 » Thu Jan 05, 2012 6:49 pm
Quint wrote:Check your boost gauge.
done, have one on loan at the mo as well as my HKS one. Both reading the same
Stott69
Postby Shrike » Thu Jan 05, 2012 6:54 pm
glad its helping :p
Why dream it when you can live it
Shrike
