New ct20b record. 365rwhp @ 22psi. Gen2 3sgte
Postby Al » Sun Jan 22, 2012 2:17 pm
From MR2OC dyno section: http://www.mr2oc.com/showthread.php?t=439258
Built 2nd gen, stock valves, GSC 268 cams, intake, exhaust, ebay side mount
Power FC
Tuned on E85 by NoShoes
Al
Postby Bling » Sun Jan 22, 2012 2:19 pm
Impressive!
Tech question?
Postby Al » Sun Jan 22, 2012 3:33 pm
Tech Questions
The place for all technical car discussions.
:P
Al
Postby iOnic » Sun Jan 22, 2012 4:30 pm
Nice! Solid power
Postby strx7 » Sun Jan 22, 2012 5:17 pm
those figures are only as revelvant as the dyno's correction factors.....
Postby Al » Sun Jan 22, 2012 6:36 pm
strx7 wrote:those figures are only as revelvant as the dyno's correction factors.....
uncorrected figures.
Al
Postby strx7 » Sun Jan 22, 2012 7:06 pm
still doesn't tell you what HP it is actually making at the flywheel.
Generally accepted dynojet WHP readings are 15% less than flywheel
Postby Al » Sun Jan 22, 2012 7:13 pm
How do you measure the engine hp without pulling the engine out and putting it on an engine dyno?
Last time I checked I drove on wheels not a flywheel.
Al
Postby iOnic » Sun Jan 22, 2012 7:25 pm
Impressive power on a "stock" turbo regardless of where it's measured from.
Postby RedMist » Sun Jan 22, 2012 10:16 pm
Al wrote:How do you measure the engine hp without pulling the engine out and putting it on an engine dyno?
WHP is what matters!
That WHP is considerably better than I had expected from a CT20b. It's more than I'm pulling from my GT2871r's.
I suspect a good portion of the power is the E85.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Al » Sun Jan 22, 2012 10:51 pm
Indeed. For a long time the record sat at around 320rwhp on a gen2 motor.
Al
Postby Dell'Orto » Sun Jan 22, 2012 10:56 pm
Totally...I think neelside's GT Four made 299kw on pump gas, and 350+ on E85
Postby BlakeNZ » Mon Jan 23, 2012 10:50 am
this is very solid(i mean impressive) for a stock turbo 2 litre. well done.
BlakeNZ
Postby cat007 » Mon Jan 23, 2012 12:24 pm
They let it run down after a high gear pull and measure the resistive force it takes to slow the dyno down?
Postby sergei » Mon Jan 23, 2012 2:32 pm
Which is a very misleading experiment.
Normally with this "measurement" people are led to believe that they have 100Hp loss through drive train (which would be realistic for quarry dump truck).
Postby iOnic » Mon Jan 23, 2012 2:46 pm
What's the obsession with flywheel power anyway? I'm personally more interested in the sum of all parts.
Postby strx7 » Tue Jan 24, 2012 9:31 am
iOnic wrote:What's the obsession with flywheel power anyway? I'm personally more interested in the sum of all parts.
flywheel HP is the only TRUE HP, because all types of hub and wheel dynos read different!!!!!! why cant people comprehend that.
wheel HP readings are only relevant from one car to another is they are done on the same dyno, or within a ballpark if it is the same type of dyno.
many years ago a vehicle was run on dynojet, dyno dynamics and dynopak dynos as an auto. the owner then converted it to manul, and ran all 3 dynos again. before the engine was put in the car it was also run on an engine dyno. the results were....
Dyno Pak manual read 9% less than flywheel
Dynopak Auto read 11% less than flywheel
Dynojet Manual read 15% less than flywheel
Dynojet Auto read 17% than flywheel
Dyno Dynamics Manual read 27% less than flywheel
Dyno Dnamics Auto read 29% Less than flywheel.
Postby sergei » Tue Jan 24, 2012 10:19 am
what power level was the engine making?
Postby strx7 » Tue Jan 24, 2012 11:02 am
about 550-600hp at the motor from memory
was a 5.something litre v8
Postby sergei » Tue Jan 24, 2012 11:07 am
strx7 wrote:about 550-600hp at the motor from memory
So the most accurate dyno would be the one that read 9% to 11% less than at flywheel, since that is most what you expect to be lost at transmission (~50Hp for that power).
