Custom made head gaskets
Postby Crown » Fri Jan 27, 2012 10:49 am
Can anyone advise where to get a head gasket made?
I was just going to take an old one to Prometal and have it laser cut out of 1.2mm copper but they need a cad file for that which would make it a very costly exercise.
Crown
Postby evil_si » Fri Jan 27, 2012 5:45 pm
Were are you located?
Theres places like Nz gaskets, gaskets unlimited,
One stop cutting shop have done metal - copper and stainless gaskets for me
evil_si
Postby Crown » Thu Feb 02, 2012 8:31 am
I'm in chch.
Is copper the best material to use?
Crown
Re: Custom made head gaskets
Postby Grrrrrrr! » Thu Feb 02, 2012 8:36 am
Crown wrote:Can anyone advise where to get a head gasket made?
Make your own DXF file if you think your measuring skills are up to it. Download any free 2D cad package that can export DXF and draw it, then send them the file. One Stop cutting shop in auckland are excellent to deal with, we send a lot of work their way.
Grrrrrrr!
Postby DRFTIN » Thu Feb 02, 2012 10:09 am
shuk might be worth a try?
down wordsworth st
DRFTIN
Postby Vertigo » Thu Feb 02, 2012 10:12 am
is there any benefit to getting a head gasket made, rather than using an off the shelf?
TVIS just kicked in, yo!
Vertigo
Postby Mr Ree » Thu Feb 02, 2012 12:02 pm
Possibly price, and making one that isnt offered in that size?
They are the only 2 things I can think of.
wak thud gush!
Mr Ree
Postby wde_bdy » Thu Feb 02, 2012 12:26 pm
Decreasing compression for boosted applications is the common reason for a 1.2mm copper gasket.
Callum
wde_bdy
Postby sergei » Thu Feb 02, 2012 1:34 pm
wde_bdy wrote:Decreasing compression for boosted applications is the common reason for a 1.2mm copper gasket.
Callum
This actually a misleading application, as decreasing compression by thicker head gasket does not reduce detonation as much as people think (in some cases it makes it worse).
If the block and head was skimmed, you might want to use thicker head gasket.
Postby edwagon » Thu Feb 02, 2012 1:40 pm
Callum
Quench areas and all that.
Now you've done it
Cue Magnit??111!
edwagon
Postby rollaholic » Thu Feb 02, 2012 5:42 pm
i think he mighta been shitcanned. maybe.
