Shaft seal, which way around?
Postby cat007 » Tue Feb 07, 2012 8:37 pm
Installing one of these onto a pump:
Do you put the side with the spring facing the water or oil, or facing the outside world?
Postby iOnic » Tue Feb 07, 2012 8:47 pm
Closed/flat side = outside world. Spring = inside.
Postby cat007 » Tue Feb 07, 2012 9:13 pm
Thanks!
Postby RunningRich » Tue Feb 07, 2012 10:38 pm
Generally you should be able to read the text on any seal like this once installed. Generally...
Don't forget a little appropriate lubricant in the bore. These lip seals work by having the higher liquid pressures squishing the rubber down onto the shaft. Zero lube will cause wear.
Richard
http://gtfour.supras.org.nz
RunningRich
