adjustables bangs and macking alot of noise
Postby tim_blair » Sun Feb 12, 2012 10:40 am
my mechanic says its quite normal for adjustys to bang and mack alot of noise when driving
he says its the pillow joint at the top
does anyone know how to reduce this noise?
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby Burning Angel » Sun Feb 12, 2012 10:48 am
a factory car has rubber bearing mounts to damp the noises out but at the expense of rigidity.
i suppose you could cut a sheet of rubber to fit between the top hat and the strut tower but again thats just introducing slop into the suspension
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby siren676 » Sun Feb 12, 2012 11:58 am
My camber plates on my car are making a bit of noise as well. I think you'll find that the pillow ball has become worn and needs replacing.
siren676
Postby iOnic » Sun Feb 12, 2012 12:02 pm
Mine are silent.
Postby 1I1 » Sun Feb 12, 2012 12:50 pm
iOnic wrote:Mine are silent.
Ditto. Just transfers extra road noise
TRD Clicky >>Here
1I1
Postby Bazda » Sun Feb 12, 2012 5:53 pm
If they are as bad you you describe then you need new pillow balls..
Postby Mr Revhead » Sun Feb 12, 2012 6:45 pm
SPHERICAL BEARINGS :P
Nothing pillow about a bearing!
But yes if it has started clattering then it is quite likely those.
Is it a rapid rattly noise?
Postby cat007 » Mon Feb 13, 2012 9:11 am
Bazda wrote:If they are as bad you you describe then you need new pillow balls..
And if they're Tein - they're about $700 for a rear pair....I know this from experience!
I didn't pay that much of course :wink:
Postby siren676 » Mon Feb 13, 2012 10:57 am
Do any traders on here get in cusco pillowballs? My front ones are poked
siren676
Postby cat007 » Mon Feb 13, 2012 10:59 am
siren676 wrote:Do any traders on here get in cusco pillowballs? My front ones are poked
I got mine through part master
Postby 1I1 » Mon Feb 13, 2012 11:00 am
Mac @ 41.co.nz does Cusco
TRD Clicky >>Here
1I1
Postby cat007 » Mon Feb 13, 2012 11:01 am
Ah - sorry mine are Tein not cusco
Postby Mr Revhead » Mon Feb 13, 2012 11:05 am
I bet they are a standard size. Check engineering supply firms.
Postby Bazda » Mon Feb 13, 2012 11:41 am
Spherical bearings which are teflon lined in that kinda size would be around $30-50 each.
Race series ones are more like $100 each which have a thicker and stronger teflon.
I use Aurora race series sphericals. They are awesome but $.
Postby phoenix » Mon Feb 13, 2012 1:17 pm
Last time I checked Autolign would supply Tein replacement pillow balls/spherical bearings for $125 + fitting + GST
I couldn't be bothered with new bearings so adapted a factory top hat onto the fronts, and locked the rear pillow balls in place to eliminate the noise.
I still have the front Tein mounts if anybody wants them to get rebuilt. Off Tein Altezza/JZX110 Type Flex suspension.
phoenix
Postby matt dunn » Mon Feb 13, 2012 8:08 pm
Mr Revhead wrote:I bet they are a standard size. Check engineering supply firms.
I wouldn't.
I had to replace the ones in my race car,
The engineering supplies place had them,
but there was twice the movement in thier new ones than there were in my old worn out one.
Ended up getting the right thing through a suspension place.
Postby Mr Revhead » Mon Feb 13, 2012 8:28 pm
Yeah you have to get the right ones! They are different spec ones and it sounds like you got ones for mechanical activation on machines etc not the high spec ones.
Postby Emperor » Tue Feb 14, 2012 7:13 pm
I thought I had wear problems when I put the D2s in the Stagea.... Nah turns out top arm is on body lol
Emperor
